Here you go mate :)
Most hard drives drives have a label showing the jumper setting for Master (MA), Slave (SL)and Cable Select (CS) or it maybe labeled on the printed circuit board.
You only need a single jumper and it is inserted in a vertical position.
There are a group of 6 pins (3 columns of 2 pins) next to the 40 pin IDE connector.
The Slave setting is usually the middle set of pins.
