Question about Apple iPod classic MP3 Player
How do i delet music off my ipod .i have just bought an ipod put my music onto but seem to have more than one song of everything i have put on ,so i need to delet some of the repeats to gain more space
Posted by sheila_white on
Anonymous
    President:
  • 2,185 Answers
Hello there Sheila,
You need to plugin your IPOD to your computer which has ITUNES installed in it. Start Itunes and you will notice form the left pane the name of your IPOD. Click for that to show list of songs on the right. Click on the songs you want to delete and press Delete from the keyboard. After you finished "cleaning". Do a re-sync on the IPOD.
Posted on Dec 01, 2009
I bought an ipod 2gig nano with 117 songs downloaded. I like maybe 30. how can I delete the other songs?
Step 1: To Delete the songs you don't like from iTunes library: Launch iTunes > Click Music mark > Select My Music > List your music as Songs > Select the songs you don't like > Click Delete to remove them. Step 2: Connect your iPod to computer > Sync the music from your computer to iPod with iTunes
Delete music files from ipod touch
Bearshare is a program that can be used to download and listen to audio files on your computer. You can also use Bearshare to put music directly onto your iPod or portable music player. Using Bearshare to add songs to your iPod will save you the time of having to search for your downloaded files using iTunes. By using Bearshare, you can download a new song and place that song directly onto your iPod without having to open another software program.
Download the latest version of Bearshare (see Below). http://www.bearshare.com/ Install Bearshare onto your computer. When you do, Bearshare will search for audio files that are already on your computer. The program will then add those files to the "My Library" portion of Bearshare. Open Bearshare. Click the "iPod/Mp3 Player" option on the left side of Bearshare. Plug your iPod into your computer. A dialog box will open on your screen. Click "OK." The "iPod/Mp3 Player" option will be replaced with the name of your iPod. Click the "My Library" option in the top left corner of Bearshare. Any songs that you added when installing Bearshare or that you have downloaded with Bearshare will appear on the screen. Click on the song and then drag the file over to the name of your iPod found on the left side of the screen. Doing so will add that song to your iPod. Continue doing this until you are finished adding songs to your iPod. Disconnect the iPod and close Bearshare.
1helpful
Itunes mistakenly put other songs onto my ipod touch and deleted all of the ones i already had and wanted, i didnt want the ones that were downloaded and i cant delete them what should i do because i cant...
I have had this problem before and it is a simple fix. What I think has happened to you is that you iPod is automatically syncing songs which I personally dont like. To change this plug in your iPod and then in iTunes click on your iPod in the left side bar and then make sure that 'Manually manage music' or similar is checked and then you should be able to go into the ipod and delete songs etc. and if you want to add music simply drag it from the library onto the iPod in the side pannel.
Hope this helps
Music on iPods with different s/Nos. mixed up
Connect iPod to computer.
Open up iTunes.
Click on the icon on the left sidebar of iTunes that says "iPod Nano".
Click on the Music tab.
You will notice that at least one folder has been set to "Sync music" - the songs in these folders will be automatically loaded onto your iPod everytime you connect it to your computer. I would suggest separating the music folders that you use and the folders that your wife uses on your computer itself. Then, you can sync only the songs in your own personal folder.
Alternatively, you can disable the "Sync Music" option altogether by unchecking the box.
Whichever choice you make, you will now need to manually go in and delete the songs you don't want.
You can do this by clicking on the Music icon underneath the iPod Nano icon on the left sidebar of iTunes. Find a song you no longer want on your iPod, right-click the song, and select delete.
-Tha Mp3 Doctor
How do i get what i accidently deleted back on my ipod
hook the ipod up to itunes and when it opens to the page that you see the picture of the ipod. put a check mark next to the automatically sync my ipod.
However, if you have other song on your ipod that are not in your library they will be delete during the sync.
No here is the best way to do it.
put a check next to manage music manually, instead of syncing it.
find the music file folder on your computer, open it up and minimize it.
open itunes and click on music under your ipod. now maximized your music folder and drag the songs into the white area with all the lines. the songs will load onto your ipod.
do only about 100 or so at a time to avoid problems.
to get multiple song click on the top song, and press shift and highlight the last song this will mark all songs in between to be moved. now drag the highlighted songs and watch them load.
Songs skip
delete the track that skips and then put it back on again and let me no if it still happenes
Cannot delete songs
Your playing with fire when you don't use ITunes to put music on your Ipod. The best way to delete them is to restore your Ipod back to factory settings using Itunes.
2answers
Songs deleted, but empty space and song info. still remain
Get yourself anapod from Redchair software, this works on older PC's and you just drag and drop songs onto your ipod.Its also very easy to delete tracks aswell.Anapod supports adding and deleting photos onto the ipod.
Deleted songs
Look in the music folder (top left of the main itunes page). You should see all of your songs there. If they are there, then plug in your ipod, click on the name of your ipod (left hand ide of the screen) and check the box on the main screen that says (manually manage music). Then go back to the main music folder again, and select all of the songs, (you can do this by clicking on the first ong in the list, hold down the shift key and then click on the last song in the list), then drag and drop all of the songs onto your ipod in the list at the left.
Can i put new songs onto my ipod without the other ones deleting?
EACH TIME YOU HOOK UP TH EIPOD IT REINSTALLS ALL THE EXISTING SONGS ALONG WITH NEW ONES. YOU CANNOT DELETE THEM AFTER YOU INSTALL THEM OR THEY WILL ALL BE DELETED THE NEXT TIME YOU HOOK IT UP.
Apple iPod classic MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Ekse
Jean Sintulaire
Vish Iyer
Vish Iyer
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
