A couple of things to check is to see if the unloader valve is working, there is a copper line that goes to the pressure switch that dumps the air pressure off the pump to allow a start under no load. with the compressor off and the tank up to pressure loosen the fitting on the small copper line to see if there is any pressure there. if there is either the valve is plugged or the small lever under it from the pressure switch is not hitting the valve to unload it. The other suspect is that the start capacitor in the motor is bad. I assume that this is a 220 volt single phase motor. you would best take the motor to a motor shop and have it tested. this is something that I would advise you have a professional do if you are not experienced with motor repair.
Testimonial: "Thank you for the information,it was very helpful."
