If the camera hs recently been dropped it may have lens damage that requires professional repair. If it hasn't been dropped, your problem may be due to weak/worn out batteries
or corrosion on the battery contacts inside the camera which can
prevent the full power of the batteries from flowing into the camera.
Try this free fix before you do anything else: remove the batteries and
wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have
a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
