Audiovox FPE3206 32 in. LCD Television Logo
Question about Audiovox FPE3206 32 in. LCD Television
Tv power comes on but no picture th name Audiovox
Tv power comes on but no picture the name Audiovox flashes every min or so also makes a wierd noise every 15-20 sec.
Posted by Rhonda on
  • 5 more comments
  • Rhonda Dec 02, 2009
    Thanks for your reply budmrtn. I checked the power suply board caps looked fine there was no burn marks or anthing i could see the board did have a ticking sound could not pinpoint it,the wierd sound seems to be the ticking sound just amplif.Please need more help Thanks critter :)
    budmrtn could not find a 24v. it has 2 sets of wires coming from the power supply board 1 set has 2 wires yellow&black that go to the bottom board left side in a case,the other plug has mor wires that go to the top in cased board left side. Im sending pictures,not the best but i hope they will help.Thankshttp://s976.photobucket.com/albums/ae241...
  • Rhonda Dec 03, 2009
    The power plug it self has 3 wires a black and a white that goes into a plug that is pluged on the power board the green wire is attached to the metal part of tv the yellow and black wire goes into a plug at the top of the board the other ends go to a plug that is pluged into the bottom case on the left side, that end has a big blob of glue from it to the metal case
    Im not sure of the numbers you needed i hope this is it. 782.L32U25-200C
    2006.07.12.V08 also the #3 im 99% sure that was it hard to tell mess up
    the yellow wire has 22 AWG 80oC 300V TITION the wires i looked at all have 300V the awgs are different pink and brown are 26 awg the whites on the same board are 24 thats the right side bottom board.Top board right side has 22awg on the brown & red & black. I am sooo confused LOL :) Dont know what i would do if you was not helping me, I realy appreciate your help!
    Thank you for help i will try to send another pic with the whole back showing im also in the USA-Ohio. I tried sending the last pics 2 different ways can you tell me if you got them by the link that was sent or by the jpg ? that way i will send the new pics the same way tomarrow.Thanks again r21c
    OK sorry i took so long i had to wait for my sun to come over and send the new picture LOL he sent it to the same link
Bud Martin
  • 11,361 Answers
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Dec 01, 2009
  • 3 more comments
  • Bud Martin
    Bud Martin Dec 02, 2009
    The ticking sound is from the power supply turning on and off because it sensing overload or false sensing due to bad power supply itself. You need to disconect the connector that is suppling the power to the inverter board, then turn it on to see if you can get the sound but no picture, if you do, then it can be the inverter board is shorted. Look for the connector on the power supply that label with 24v. Pictures?
  • Bud Martin
    The connector with Black and Yellow should have 5VDC on the Yellow (meter positive lead to the YELLOW wire, meter black negative to the metal chassis of the TV), the other connector with RED should be 24vdc and Black wire (negative), the other connector with black (hot/line) and white (neutral) are for 120vac incoming line voltage- be real careful here. The picture on the left side show the inveter board whic is under the grilled cover with a bunch of pink and white wires attached to the left side, you should be able to remove the grill and then remove the connector on the right side of the inverter board. Then check to see if yoo voltage reading on the red wires of the power supply board. Can you also give me the printed numbers on the power supply board itself?
  • Bud Martin
    Bud Martin Dec 03, 2009
    I Google the number you give me '782.L32U25-200C' is the correct number for the power supply. You can get the replacement here:
    http://www.discount-merchant.com/We-prov... but they are 0 stock right now. Somebody in UK also selling repair kit: http://www.chsinteractive.co.uk/electric...
    So it must be common problem with this power supply to fail. Are you in thge US? My email:[email protected], I am in California. SF Bay AREA.
  • Bud Martin
    Please send me the picture of the whole chassis that show all the modules in one picture?
  • Bud Martin
    I tyr the link http://s976.photobucket.com/albums/ae241..., but i do not see any new picture, send them to my email address also.
Anonymous
    New Friend:
I have repaired this twice on mine..it is a bad resistor you will find burnt between the capacitors..replace it and your good to go for about another year...when it burns out again replace it and your good for another year...you can kinda see where im goin with this.... 30 cent part vs. new tv...i opt for the 30 cent part
Posted on Sep 07, 2011
  • 1 more comment
  • mo01gte Sep 16, 2011
    can you provide the resistor value, mine is burnt and can't see any of the color strips, I can replace it if I knew the value
  • Anonymous Oct 02, 2011
    It originally was a 3 amp I replaced mine with a 4 amp
  • Anonymous Jan 16, 2013
    sorry could give the resistor in ohms as mine is burnt and cant read the colours thanks
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
7helpful
Plasma tv picture not coming on and power light flashing
Yes, you have power supply issue.
the power on circuit is malfunctioning and the flashes is the indication that the voltage levels for the power on regulation is not correct therefore shut down to protect the circuit from further damage. You TV unit needs servicing by an plasma TV specialist.
Also check to see if you do not have the TV in sleep or hibernation mode.
I changed the bulb in my tv and it was working for a few days. Now I get audio but there is a wierd electrical clicking noise which made me think the new bulb broke but I still have a green light on the...
In this case there are two possibilities of what part is the one causing the issue, it coul be a ballast because of the clicking sound that caused the tv to shut off, and that buzzin sound is for your color wheel that it might not be working anymore, discountdashmerchantdotcom free troubleshoot
I have a rca 32v343t atc010a and when i turn it on the power light comes on and the tv makes a noise like its coming on but then theres no picture or sound. I would like to finde out whats causing this to...
It sounds like the High voltage transformer has gone out. If you open the back of the tv and look on the right side, you will see a large (4 - 5 inch) black cylinder with a large wire coming out of the top. without touching anything, look and see if it is cracked.
23helpful
6answers
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Problems with my sony kv32fx20u tv
sony kv36xbr400 wega I have a 5inch black line across top and bottom & gray side to side making a smaller picture.
2answers
Wierd sound when I switch on the TV
Your TV may something arcing inside of it. Maybe a loose connection. Since it is probably under warranty you should get in touch with the dealer where you purchased it. Perhaps you can get the whole TV replaced. Stargazer
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
