1996 Ford Taurus Logo
Posted on Dec 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fans are continuing to run after the car is turned off
Dave Sargent
Level 3:
  • Master 488 Answers
  • Posted on Dec 01, 2009
Dave Sargent
Master
Level 3:
Answers
488
Questions
Helped
170751
Points
1538
If the fans run on for a short time (upto five minutes) and then stop after you have shut the motor down, this is normal!! If the fans simply do not stop at all, check the fan relay as the relay may be faulty.This relay is located in a housing with other relays under the hood. They may be marked as to what circuit they belong too, look in the lid.. If they are not, pull each relay out in turn until the fans stop. Those relays which have no effect should be replaced before you pull the next relay out. Some relays can be opened and some cannot, either way, just replace with a new relay as once the contacts stick once, they will continue to stick..
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
Helped
7054
Points
57
Thats supposed to happen, its cooling your car down..it will shut off once the car is cooled down
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
5978
Points
36
THE FANS ARE SUPPOSED TO RUN ON AFTER THE ENGINE IS TURNED OF THIS IS TO ENSURE THE ENGINE COOLS DOWN PROPERLY SHOULD ONLY RUN FOR A SHORT WILE THOUGH AT MOST 2 OR 3 MINS HOPE THIS HELPS
Why does my fan continue to run after car is shut off?
Which fan are you referring to? The pusher fan in front of the radiator is tied to the AC system. If it continues to run for an extended period after you turn off the key, then there is likely a problem with the relay. I think your model year has the 2 speed fan. Does the fan run at high speed or low speed when you turn off the car? Does it do it if the AC is off?
Cooling fans continue to run when engine is shut off
This is normal. Cooling fans today are not turned by the fan belt but are run by an electric motor. The fan continues running until the coolant temperature is reduced
Cooling fan runs continuously, even after replacing both relays coolant sensor.
Could be that you have 2 Thermal sensors as some cars have one for the dash gauge or light and the other is for the PCM.
Remember that when you turn on the A/C it can trigger the cooling fans to run continuously. If the A/C is left on while you are doing all of this, it can be a simple reason for the problem.
Please rate my info.
I have reno megane 04 my fan continues running when my car is not running i have had the air presureit has just happened again sensor replaced bu
Many cooling systems are designed to let the cooling fan continue to run even after shutting down the engine...however, this should only last for a minute or so...your owners manual may help. If the fan never stops when turned off this is probably a faulty resistor...may need a good mechanic to confirm which...Hope this helps.
Cooling fan continues to run after engine shut off.
The fan runs for a short time, after ignition off, to continue to cool the hot engine.
Car will not start, fan is draining battery I believe, not sure
boost vehicle but before you do that remove the fuse for the cooling fan till you get it to turn over once its running plug said fuse back in and get it to a shop to have them diagnose why the fan is on to long
Cooling fan continues to run after turning car off
Try change the Fan Assy....there a small box with state (Gate) on the upper right of fan assy... it does controling the sped of the fan...
3helpful
The electric radiator cooling fan will not turn off
As long as the fan eventually shuts off this isn't a problem,the fan will continue to run for a bit after the car is turned off,once it reaches a set temprature it will turn off.
AC/Heat Fan runs continuously and Rear end roaring noise
Sounds like the wheel bearing on the right rear hub may be defective, that would cause the noise if the tires are ok. As far as the fan goes not sure this isn't working as designed.
1helpful
Dodge dynasty electric fan doesn't turn off
On some vehicles, the fan will continue to run for a short time after turning the car off. But if it runs for more than 5 minutes you may have a bad sensor or stuck relay
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
