There are at least 3 places where paper can be jammed in this model. Are you sure you have cleared the jam completely? Here are the instructions for your model:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_006.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=4
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
SOURCE: Printer keeps saying paper jam even after all doors are cleared of paper jam. Reset didn't work.
Dear, there is very minor mechanical fault but it is better to visit the repair shop to fix it.
Best regards
SOURCE: Printer keeps paper jamming when i go to print. I
check to see if their is a paper size adj. it might be on legal length si=ze and you are getting 1 and 1/2 sheet duration and then shut down
SOURCE: paper jam, with error signal.
It tends to be the problem of roller. Roller is not moving smoothly, just manually move the roller to and froth and then close the lid properly. Now try to take a print it will work fine.
Hope this helps.
Shane
