Question about Ecoquest Breeze AT Living Air Purifier
Does the breeze at have one or 2 fuses - Ecoquest Breeze AT Living Air Purifier
Posted by jsassy701 on
Stephen Lam
    President:
  • 670 Answers
It has one fuse. A 1.0 Amp slow blow for 110 volt models and 0.5 Am slow blow for 220 volt models.
Posted on Dec 24, 2009
No power is getting to model s1730 sharper image ionic breeze after taking it apart to replace light bulb. Is there a fuse in this model?
yes there is a fuse on the board located at the base of the unit...if that does not fix problem replace unit.. :)
I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
Jun 21, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
I HAVE 2 MODEL SI861 IONIC BREEZE UNITS. I BELIEVE I BLEW THE FUSES BUT CANNOT FIND OUT WHERE THEY ARE LOCATED. CAN ANYONE PLEASE HELP. THANK YOU.
There may be a thermal fuse in the vicinity of the motor, it may be held to the motor, there will also be one wrapped in the windings just for the motor, or it may just be covered with a section of black shrink wrap. It will have a current rating and a temperature rating as well. Otherwise look closely on the control circuit board as a "pico fuse" really small fuse can be there. It's only indicator will be a current rating like "2A"
Feb 13, 2012 | Sharper Image Professional Plus Ionic...
Blows fuse
Cool. How about a rating for me on this one? Thanks!
Dec 13, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Will not turn on Have checked switch under filter Have checked continuity of the fuse plates are making contact Ecoquest Breeze AQ
Have you checked the fuse? It is located in back of the Breeze in the fuse holder next to where the plug connects to the purifier. It uses a 1.0 Amp slow blow for 110 volt models and 0.5 Amp slow blow for 220 volt models.
Oct 28, 2009 | Ecoquest Breeze AT Living Air Purifier
My wife wanted me to take it apart to clean it properly. we have the quadra which all of you know that it's impossible to clean. Well, after cleaning it, I noticed a fuse which is permanently in place...
You can replace the fuse by soldering a new one into place -- it's a standard fuse, just match the amp rating of old to new.
Chances are though, after you do this, it will blow again. So, there's a good chance the unit is kaput.
I have extensive experience with these units to the point of even replacing the high-voltage field wires (the two fine wires which run from top to bottom) with titanium wire. There is no real good way to keep these things running properly -- they're kinda like weed whackers -- inherently problematic.
Apr 20, 2009 | Sharper Image Professional Plus Ionic...
My Ionic breez model no: S1861 is not working now. It was working fine last week until 2 days ago, there was no light when I turn it on. Before that, I heard sound buzzing and I've cleaned the grid well....
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Aug 06, 2008 | Sharper Image Professional Plus Ionic...
Sharper image ionic breeze air cleaner
Jul 15, 2008 | Sharper Image Professional Plus Ionic...
Ecoquest breeze problems
You might want to make sure that the back screen is in the whole way. I had that problem and that fixed it. What size fuse does it take. I am trying to find it. I through it out with a DVD fuse and don't know which was which.
Apr 27, 2008 | Ecoquest Breeze AT Living Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
168 people viewed this question
Top Ecoquest Air Purifiers Experts
Tafi Nami
Tafi Nami
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
