Question about Mitsubishi WS-65615 65" TV
How do i set video from 480i to 1080i?? - Mitsubishi WS-65615 65" TV
Posted by lrborg on
Shahid Electronics
  • 10,594 Answers
1080i picture resolution can be achieved through HDMI input only. If your TV and Video Source (dvd player, cable box etc) has HDMI jacks, plug HDMI cable between them to get 1080i picture.
Hope this info will help you.
Posted on Nov 30, 2009
Dave Naylor
  • 834 Answers
When your using the comp in or hdmi the tv should swithch automaticlly but you must have an HD signal
How do I change settings from 480i to 1080p?
Set the unit to DTV input (this uses YG,PyR,PbB) . then in customer menu go to advance features, SD video format & change from 480i to 1080i. There is no 1080p
Feb 15, 2015 | Mitsubishi WS-65809 65" Rear Projection...
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
My TV is only 480i. When my receiver reboots, I cannot see the settings menu to configure the receiver to output to 480i. I need to know the remote keystrokes to press to configure the receiver for...
You did not give your model number of receiver. Some of the ones from 2007 or so have a switch on the back for video resolution, 480i, 480p 720p 1080i so set this switch to 480i.
Mar 08, 2011 | Samsung HDTV Digital Terrestrial Receiver
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Full hd capable, but only functioning in 480. how do i set my monitor to 1080?
i would have to know what type of connection you are using. usually in most hd monitors, the vga plug will only show up to 480i/p and some will show 1080i. DVI will only show 480i/720p/1080i and if it has an HDMI you can get 480i/480p/720i/720p/1080i/1080p. you will also have to set you resolution of your video card to match.
Sep 18, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
My ws-65611 always stay in 480i even with HD signal.
If you are using the component connection, make sure you are connected to the one that will support 1080i. If that is not the problem, make sure that the HD receiver is outputting 1080i and not 720p. No RPCRT will support 720p and the video may be down-rezed to 480 since this is the case.
Jan 25, 2009 | Mitsubishi WS-65611 65" Rear Projection...
The display only goes between normal and zoom
This is an EDTV capable of 1080i over component cables. It will also display 480p & 720p. Most likely its the video source determing the resolution you are seeing.
Nov 14, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Daniel
It'll still be 480i, it'll just work on a 1080i input now. You can't make HD out of a non-HD source.
Geno
Jan 24, 2008 | Televison & Video
Getting my Sony TV to operate in 1080i.
Asumming you have set the Xbox at 1080i in the video settings and you have used all the four component lead ends, (apart from the yellow video end, as you won't need this) it should work.
Jan 11, 2007 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Mitsubishi WS-65615 65" TV Logo
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
