Question about Hotpoint HTR16BBSR Top Freezer Refrigerator
Noises in freezer area of refrigerator
Why does the freezer make loud crackling sounds? This is only 4 years old.
Posted by koch81 on
Mike Smith
  • Hotpoint Master
  • 1,606 Answers
The sound could be , when the refrig goes into defrost , every 8-10 hours , the heater heats up the ice , causing the ice to "crack " , on the coils . This will be a normal condition , as long as the refrig keeps cooling .
Posted on Dec 01, 2009
Faisal Rafique
    New Friend:
  • 60 Answers
Some refrigerators have a small plastic fan under the bottom shelf of the freezer that circulates air. It's not too unusual for a heavily loaded shelf to rub the fan blades making the noise you describe. If you empty the freezer, you'll fin a few screws holding the bottom shelf in. remove the shelf and inspect the fan and surrounding parts for signs of rubbing. Also tug on the fan blade lightly to see if it is still attached to the motor's shaft securely. New fan blades can be purchased at a good appliance repair shop. Good Luck
Posted on Nov 30, 2009
3 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Refrigerator making loud noise and fan: help!
take raer panel off inside freezer and check there is no ice build up which is hitting the fan
Posted on Jul 18, 2008
dennis dodge
  • 1891 Answers
SOURCE: My Kenmore refrigerator is making a loud noise
the clunking sound that it make's when the compressor shuts off is bad motor mounts / and may be the internal also . this would also cause the loud running sounds . if it starts every 10 min it may be short cycleing . ( clean the coil's and make sure the fan in back is coling the unit .. and make sure you replace the back when your done .. mm
Posted on Dec 03, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Hotpoint G/E Side by side refrigerator Model
There is ice build up hitting the fan....
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 25, 2010
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
When the compressor (thermostat?) shuts off, it makes a very loud noise. Freezer and refrigerated area are keeping things cold just fine. Refrigerator is 12 years old.
The compressor has 3 or 4 internal motor support springs . Over time , one can rust , due to the contaminates in the refrigerant system . One of them can break free , which will not cause any damage , other than a clunk , when the compressor cuts off . You can still have many years of correct cooling , only the noise will be present .
Nov 19, 2009 | Refrigerators
Our LG bottom freezer refridgerator is 2 years old. It is making a whirring noise that stops when the door is opened. It can get pretty loud at times.
The whirring sound is the fan that blows cold air into the refrigerator. It is supposed to stop when the door is opened. If it is making a loud noise there may be ice built up in the fan housing. Turning the power to the refrigerator off for a 2-4 hours may allow any ice in the fan to melt. If you do not open the freezer during that time the frozen food will not defrost.If the noise continues, you may have to take the fan apart to make sure it is not frozen. It is probably located behind the back inside panel of the freezer.
Nov 02, 2009 | Refrigerators
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
A three loud consecutive popping sounds at various
You probably have a bad compressor. It's internal parts are held up with 4 springs and one of them has probably broken and causes the compressor piston to hit the side of the comp. housing. This will happen when the ref. shuts off. To be sure, if you turn the ref off at the controls then you should hear the noise in the back. If it is less than 5 years old you can get it replaced under warranty. if more than 5 years old it will just be noisy. it will most likely last several more years like it is. Let me know if I'm right.
Apr 01, 2009 | Frigidaire FRT21H8 Top Freezer...
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Crackle noise and hissing - panasonic
solder all around the flyback area if this not resolve the problem replace the flyback
Nov 26, 2006 | Panasonic CT-32D12D 32" TV
Hotpoint HTR16BBSR Top Freezer Refrigerator Logo
208 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
