Philips 27PT5445 27" TV Logo
Question about Philips 27PT5445 27" TV
My tv when turned on goes to a black screen with 3 color strips of lines going across the picture then goes to a snowy picture but only shows on half the screen and then shuts off
Posted by rmaceachern on
Anonymous
    Scholar:
  • 101 Answers
This sounds like a vertical problem. It could be just a bad solder joint or it could be a IC that has failed and surrounding componets. Hope this is helpful.
Posted on Dec 04, 2009
Color on half the screen has cool tones and half the screen has warm - different color tones on each half
Try to reset the picture back to default settings for the picture on your TV or there could be a problem with the HDM cable and the HDM cable needs to be replaced or there is an issue with the TV screen it's self and the colour with your TV too.
1helpful
How do I fix my Sharp tv from right side to center there's a half inch black line 9 inches down from top on screen and it changes color depending on background and UNDER the line the image is blurry a
If this is done with every input of your tv and also with tv channels this means a bad circuitboard .You can find on ebay one and mod it yourself. Its not such a difficult thing.
TV HAS A COLOR LINE WHEN IS ON IN THE MIDDLE OF SCREEN
if it runs across the screen its a buffer board usually. Can you paste a picture of the line?
Toshiba 27A40 has single colored line across enter
Vertical output has cracked soldering. Around $150 to fix.
2helpful
32'' Insignia LCD is flashin colrs. wh,blk,rd,grn,blu. audio wrks
It could actually be quite a few things, loose wire, loose solder piece, bad crt's/picture tube, bad system board, or others. It's would have to be diagnosed with testing equipment. It will probably cost you another 150-200 for the new part to be put in.
1helpful
2answers
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
2helpful
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
2answers
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Large Black Strip across the bottom of the (TV Cable) Picture
This happened to me too and i fixed mine by going into settings and for some reason my subtitles were turned on. turn it off and it should fix it.
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
