Question about Philips HD6153 Deep Fryer
My superior deep fryer turns off including the pilot when it reaches about 300 or 350 degrese. this problem started after i cleaned it. iits a comercial gas fryer in my restaurant
Posted by playboi626 on
Anonymous
    New Friend:
HEY, MY NAME IS KEVIN AND IM IN THE RESTAURANT BUSINESS AS WELL. IVE HAD THAT SAME PROBLEM,THE FIX IS TO REPLACE THE THERMO COUPLER. PART COST ABOUT 40.00 - 50.00 BUCKS DEPENDING WHERE U FIND IT. ANY QUESTIONS UFEEL FREE TO EMAIL ME. [email protected]
Posted on Jan 13, 2010
Pilot goes out after fryer reaches operating temp. Replaced milli-volt generator already.
sometimes the hole in the pilot tube gets dirty and needs cleaned in the old days the gas man had a tiny drill bit he reamed it with .
Mar 05, 2015 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Commercial Deep fryer pilot light switches off when approx 180cel is reached
The second guy is spot on this page on fixya has not been working first time i have seen the problem .
May 31, 2012 | Frymaster Dean MJ35 Deep Fryer
Pilot blows out as soon as tempiture is reached
try removing all electrical connections and polish all contact points (emery cloth) including screws. Also try tapping on the regulator, magnets may be sticking. Thermocouple for pilot may be defective.
May 05, 2010 | Pitco Frialator SG14 Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Shallow fryer pilot light goes out
Call fafctory service dept 800-637-9188 ext 22
May 27, 2009 | Comstock-Castle 14HF Deep Fryer
Hobart deep fryer, light pilot heats to temp then all goes out?
You will need someone who is qualified in commercial gas appliance repair to fix this.
Liabilities would render this out of reach for anyone else.
Mar 29, 2009 | Hobart 1H50D Deep Fryer
Pilot goes out when fryer reaches set temp. and shuts-off.
try to change the thermal battery the device that the pilot heats.. other wise there is a screw at the botton of the automatic valve.. try to increase the pilot so it can heat more the thermal battery! u dont have enough voltage to activate the solenoid valve so thats why ur pilot goes off
Mar 09, 2009 | Vulcan GR35 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Vulcan Deep Fryer Need to Light Pilot
you have to hold the knob in after pilot is lit for at least one minute
Jul 09, 2008 | Vulcan EF3 Deep Fryer
Gf 40 frymaster fryer
Hi, I am suposing that this fryer has worked good in this location before. If not, check to make sure it is set up right for your gas supply. (LP-Nat) There is something wrong with the gas - air flow in your unit. Look for obvious things first like exhaust being blocked, Flame dancing out side of fire area, Pilot too small, Build up of debris in fire box. The pilot should be able to be adjusted at the gas valve if it is too small. I believe you problem could be taken care of best with a good cleaning of the burner, fire box and pilot assemble. Make sure that all burner holes are clean especially around the pilot light. Check for oily debris inside the fire box to make sure its not leaking into the fire area. If you are unable to do this yourself, contact some one either in the restaurant equipment service business or heating and air conditioning business. Hope I have helped you. kstfas NOTE: If this answer does not rate at least 4 marks, (almost there) please do not rate. Thank You.
Sep 26, 2007 | Frymaster Dean GF40 Deep Fryer
Philips HD6153 Deep Fryer Logo
325 people viewed this question
Top Philips Kitchen Appliances - Others Experts
Thomas Perkins
Thomas Perkins
ray gallant
Kardoc
Are you a Philips Kitchen Appliances - Other Expert? Answer questions, earn points and help others
