Otherwise Paragon timers and parts have been discontinued,,, and maybe somebody is making knock-off trippers and selling them for $15 per pair and ripping folks off.
Gene
Paragon no longer makes timers, except for commercial defrost series. There is a cheap knock-off that looks like the old 4001, but I cannot find seller any longer and do not recommend.
Paragon 4000 series uses X2772 tripper Paragon is no longer making timers except for defrost times. There is a new line of timers coming from China that looks identical to Paragon 4000, and uses same tripper. As a result this timer design and trippers could be around for years to come.
Paragon no longer makes timers or parts, except defrost timers. Typically, defrost timers are not used for pools. Open following link to possibly identify timer and tripper part number. http://waterheatertimer.org/Paragon-timers-and-manuals.html
Cross-over wiring is as follows: Paragon terminal 1 goes to T101 terminal 1 Paragon terminal 2 goes to T101 terminal 2 Paragon terminal 3 goes to T101 terminal A
Add a comment for more free help. Also take advantage of fixya phone service. For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project. Fixya is always less expensive than a service call.
Link below has Paragon EC7000 series timers and manuals EC7004/120 is 7-day programmable timer. Single channel 120Volt SPST NEMA1 indoor timer. Program up to 16 events per week http://waterheatertimer.org/Paragon-timers-and-manuals.html
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting. It is impractical to write out those steps when they appear in manual. http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
2600 series is mechanical interval timer. 26006-00 can handle 10 amp loads.
Interval timer is a countdown timer that keeps Load turned on for set amount of time. You set the time by rotating dial
To start timer, Rotate dial from 1 minute to 30 minute. Rotating dial turns on Load and begins countdown. Timer turns OFF Load after set amount of time expires.
Paragon 4000 is a mechanical dial-type timer You probably have Paragon EC4000 digital timer: Single channel, NO, NC contacts, SPST with 5 poles or SPDT with 8 poles.
