Hi Alon, as you say, it would be very possible that the main board is responsible for the malfunction of your Vizio TV
Because you say you have no image, no sound, assuming you turn it on knowing what input it is and there is some ymagen and sound, but the TV does not show you anything
If you were to have sound, there could be the T-Con board, since this does not affect the audio
I hope you can solve the problem
Greetings Franco Dosil
Hola Alon, por lo que comentas, seria muy posible que la placa principal sea la responsable del mal funcionamiento de tu TV Vizio
Porque dices que no tienes ni imagen, ni sonido, suponiendo que lo enciendes sabiendo en que entrada esta y que ah? hay alguna imagen y sonido, pero el TV, no te muestra nada
Si llegaras a tener sonido, ah? podr?a ser la placa T-Con, ya que esta no afecta el audio
Espero puedas resolver el problema
Saludos Franco Dosil
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
The main power supply regulator bard to your TV should be troubleshooted. This is a very skilled work and fatal too, for an unexperienced one to work with. it will be best for you to contact any experienced service technician. In most cases, the board might be replaced as card basis.
Sounds like the fan is going out! Or the filter needs to be cleaned! Check the back to see if the fan motor is running? Check the filter to be sure it is clean. I hope this helps you.
Parece que su problema es solamente de configuracion fisica and programacion. Empesando conecte su cable al televisor y programe por el menu los canales que se van a recibir por el cable y no por una antena exterior. Sin el cable puesto y el televisor prendido y el volumen alta debes de poder escuchar sonido rasposo porque no hay imagen. Si acaso hace eso entonces tu televisor no tiene problem electronica y es como dije anteriormente. Buena suerte y dejame saber algo. Que Dios lo bendiga.
