HP PSC 1210 All-In-One InkJet Printer Logo
Posted on Nov 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The check printer carteridge light is blinking and an E shows up in the number of copies window. When the color carteridge is removed, the check carteridge light still blinks but the E turns back to a 1.
Anonymous
Level 3:
President:
  • Master 787 Answers
  • Posted on Nov 30, 2009
Anonymous
Master
Level 3:
President:
Answers
787
Questions
0
Helped
415409
Points
2913
You have a failed cartridge.Printer need both cartridges to initializing and working.Replace color cartridge, if not help replace black too.
Show e on copies and check ink cartridge light is blinking with new ink cartridge
With "E" ,check cartridge LED which is blinking mono or color replace it, or else check paper LED if its blinking check for the paper jams..
I have put a new cartridge. On starting my printer i have check cartridge light blinking and E inthe place of number of copies .i could not make copies but able to get printout through my computer
Make sure your replacement cartridge is fully seated and locked down correctly. The E is telling you
that the printer thinks the new cartridge is not there. Some HP models are very particular with how the
cartridge is installed.
An additional test. Can you thru the computer to a test print and have the replacement color show up on
the print out?
7310 All In One - running windows 7 64k OS problem: error blinking msg: error remove and check color cartridge. This is a fairly new cartridge, I have removed color cartridge rubbed it on a damp cloth -...
you need to change it, maybe you damaged it while trying to get it working. the clearly shows a faulty cartridge remember it can be faulty even as new or from the box
4helpful
2answers
All the lights on my HP 1350 printer are blinking and it will not print. Normally where you could put the number of copies i " E" is in thaat spot.
In addition to providing information about current tasks, the lights on the front panel can also indicate error conditions, as described in the table below:
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HPPSC.
2 Turn your HPPSC off and on by disconnecting the power cord and reconnecting.
Alternatively,
All ights blinking: An error caused the HPPSC to stop functioning.
1 Turn the HPPSC off and then on.
2 Restart your computer.
3 If the problem is not corrected, unplug the HPPSC and plug it in
again.
If the problem persists, contact HP.
Cannot copy
Remove the colour cartridge and then see : "E" is displaying in its display board. If "E" appear then put it back in carriage and remove black cartridge. If "E" doesn't appear it means your black cartridge is not working properly. and vice versa with colour cartridge. This problem is belongs to cartridge. Try to change them. Problem will automatically solve
k24674
Grand Canyon Tech
Grand Canyon Tech
