Televison & Video Logo
Question about GPX Televison & Video
Do you have software converter from a VOB
Do you have software converter fora VOB file to AMV file
Posted by natureschain on
Vinho Xie
    Genius:
  • GPX Master
  • 1,309 Answers
VOB file is a container file format in DVD-Video media. So you need to convert VOB to WMV, which is highly supported by most of player. To convert vob to wmv file, you could use Leawo Video Converter, a media converter that integrates all the functions of HD video converter and general video converter. Or you can try to play the VOB file with some free VOB file player.
Leawo Video Converter ' leawo.org
Free download Leawo Video Converter the best windows video converter to help you convert videos between all popular video formats at high speed
How to Convert VOB to WMV on Windows Mac ' leawo.org This post shows you how to convert VOB to WMV on Windows and Mac with professional VOB to WMV converter program or online VOB to WMV converter
Posted on Mar 17, 2022
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
You can try using vob converter for mac. It is useful for converting videos into different file formats.Try it !!!!!!
Posted on Oct 27, 2011
Adnan Bhatti
    President:
  • 1,188 Answers
Check out the link below for your requested software:
AMV Video Converter (Scroll down on page and click on freeware free download)
Posted on Nov 30, 2009
5answers
Converting itunes videos to amv files for my kids mp3 My kids want music videos for the mp3 players....mp3 only support amv files....itunes downloads won't work with...help
I have been using this program with real good results. It will convert any video into a mp4 which is what you need. http://www.any-video-converter.com/products/for_video_free/ Copy this address into a new window.
6helpful
2answers
I can't put videos on my mp3/mp4 player
Sir please connect your device to your computer and see if any indication is shown on the display of your mp3 player
if yes then open my computer and a new device will appear under the removable devices...please open it and if there is a folder named mp3 to music then also open it and copy paste all music you want
If not then please make sure in the settings of the device that USB is set to MASS STORAGE MODE
Thanx and i hope this helps
PLease rate this solution
2helpful
4answers
Can't import vob files into windows movie maker
To use Vob files with movie maker, they need to be converted first. This can take a little while, but there is no other way, as windows doesn support dvd playback by default, and whilst codecs will give you playback, movie maker will not accept them, even with the codecs. To convert your vob files to "avi" (the format needed for movie maker) yoou will need converting software. Most of this is very expensive, but thankfully, one of the best is actually free! It's name is "super" and it can be found at the following web address http://www.erightsoft.com/S6Kg1.html
By the way, the download link is at the bottom of the page.
Wish you the best of luck,
06castwo
2answers
AMV movie dowloads - JNC Movie Mojo ( SSFM-220 )
How to convert wmv, asf, avi, mpg to amv files? iOrgsoft AMV Converter is an easy to use video-to-AMV and AMV-to-video converter application that enables you to extend MP4/MP3/MTV capacity by converting various video files into AMV workable format. AMV Converter has powerful editing capacity that you can customize source video files into different resolution, bitrate, frame rate, etc.
If you have lots of video sources but unable to get them onto your player, AMV converter should be your ideal choice. Please follow the guide below on how to convert AMV video file to or from using the iOrgsoft AMV Converter.
spacer.gif icobuy.gif Buy Now spacer.gif icon-downarrow.gif Download RMVB Video Converter free trial spacer.gif How to use video to amv Converter
How do you convert video files into AMV video files that are compatible with your mp3 mp4 player?
Step 1. Download and install iOrgsoft AMV Converter
iOrgsoft AMV converter is a simple-to-use program with intuitive way of operation. You are supposed to download a trial version to evaluate the program by converting video into AMV, we welcome you contact our customer service with your problem.
Step 2. Load video info
Click ADD Files to load video info. You can load as many video files in different formats as you like, the batch mode and powerful code pack within the program can easily take care of every thing.
Step 3 Change defaults setting
After load video files, you can now tweak various values that directly impact on the output result. Hit Option will open a window where you can trim, crop and add effect to the source video. Finally, check the box before Merge Files into One on the bottom of the panel, all the files can be merged into one then.
Step 4 Convert video
Hit Start, the entire list of source video will turn to your delivery format as you preset The time takes vary file and setting you have made..
2helpful
5answers
I need help with Craig CMP622E MP4/video player
for the video issue, I've found that when I'm downloading something from youtube or something like that, if I save it as a .wmv file it will convert it, and for limewire the videos I download are all .avi and those can be converted as well. Hope this helps a bit :D
2answers
Converting wmv files to vob
Do you have DVD burning software? If not, you can download software that converts and burns the files directly to DVD. Such software is Wondershare WMV to DVD Burner and other titles linked on this page (free trials): http://www.download3000.com/download_47402.html
3answers
Video files
Try put in it in manually Go to the following folders Record > AMV > and put the video in there....remember the video must be converted into a AMV file
Top GPX Televison & Video Experts
Jaime Hernandez
Steven Wander
Steven Wander
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
