Good evening,
I have the symbol ls-2208 scanners attached to my POS systems and they work fine. I also have them attached to a pc in the warehouse and what it does is that it scans a specific barcode and adds a zero digit at the start of the barcode something that my POS systems don t do. I ve tried programming it with the scanner manual page but havent got a result till now
SOURCE: Symbol LS-9100-4008A
Hi I'm trying to find keyboard wedge Configuration to re-program my scanner
It's a symbol LS-9100-400BA and connections if you can fax to 1-956-546-8752
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
SOURCE: Symbol LS2208 RS232
Go to the LS2208 quick start manual scan the "Set Defaults" barcode and it will return the handheld to factory default.
SOURCE: Symbol barcode scanner LS4071 + base RL475
Hi, you will need the 25-17821-20 and STI80-0200R cables to connect to PS/2. You must have a PS/2 keyboard for this connection.
If you would prefer to connect to a USB port you should get the 25-17821-20 cable with the STI85-0200R.
The RL-475 was for the IBM, but it also supported Synapse which is the STI cable.
