Question about Sirius Satellite Radio Sirius Starbase SC-FM1 Satellite Radio Receiver
Satellite radio receiver is located on roof. Is now covered.
I have a 2007 dodge mega cab, diesel 2500 with the factory radio (sirius radio option). I am putting a roof rack on. When I do this it will cover my sirius radio receiver which is located on the roof. What can I do to continue getting reception? Can I put an additional receiver on the dash?
Posted by larryramage on
Anonymous
    New Friend:
    Problem Solver:
  • 11 Answers
U have to relocate the antenna for the sat radio
Posted on Nov 30, 2009
Where is the cab air filter located for a 1500 2007 Dodge crew cab?
I have called many people and looked just about took my dash apart dodge dose not have a cabin air filter
Jul 08, 2011 | 2007 Dodge Ram 2500 Mega Cab Laramie
Where is a/c filter located in a 2007 dodge megacab 4 x 4 diesel 5.9 liter?
They do not have an a/c filter. The mega cab does however have a screen on top of the hvac unit that is used for the airflow to the rear vents. The screen was removed in some cases to improve airflow to the rear vents. The instrument panel must be removed for access to it.
Apr 20, 2011 | 2007 Dodge Ram 2500 Mega Cab Laramie
I have a 2009 Dodge Ram pickup with factory sirius radio. When I put my cab over camper on it I lose the sirius radio signal. Is there a external antenna that will work with setup . I can mount it on top...
We had the same issue with our 2007 Dodge Ram truck. We use an external antenna when we have the camper on. You can buy these at various places on line. Get the car antenna not the home antenna. It magnetically mounts onto the truck so we put it on our hood and routed the antenna wire through the passenger side door. Our satellite box is behind the glove box. Remove the glove box and look up in the cavity. We were able to just unplug the factory antenna and plug the external antenna in. It's easy to switch back too. Just be careful with the antenna wire because it's fragile and any little bit of damage makes it useless.
Jul 04, 2010 | Sirius Satellite Radio Receiver
I have a 2007 Dodge 2500 5.9lt diesel. Recently
Try this website to download a free manual
Trouble trees are listed for all makes in the manuals for dianogstics
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 01, 2010 | 2007 Dodge Ram 2500 Mega Cab Laramie
Receiver not "receiving"
where is the antenna located make sure it is not covered by anything. Also make sure there are no kinks or breaks in the antenna wire
Sep 11, 2009 | Sirius Satellite Radio Sirius Starmate ST1...
Sirius Antenna
You may have to go to your nearest electronics store or Sirius vendor to see if they have an extension cord...as a Sirius customer i never seen one though......Your best bet is to remount the antenna to the forward part of the roof, towards the windshield.
Dec 10, 2008 | Sirius Satellite Radio Receiver
Sirius satellite radio
You will need to get another sat antenna, and locate it somewhere either above the camper, or where the camper does not obstruct the antenna. Any store that sells sat radio equipment (Fry's, Best Buy, etc) will have the micro antenna. Install it either on the hood of the truck, or on top of the camper. You will need to run the antenna to the rear of the dash. They make Y couplers that will allow you to run both the OEM antenna and the extermal antenna at the same time, and it will not hurt the system to have both wired in at the same time.
Oct 01, 2007 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Antenna hookup 2007 dodge ram
Just take the fakra connector (plastic piece) off and it will be just like the sirius antenna end. Then buy a 10ft extention cable... I've just order mine and will have pics when done
Aug 15, 2007 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Sirius Satellite Radio Sirius Starbase SC-FM1 Satellite Radio Receiver Logo
245 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
Perry Mellott
Perry Mellott
Colin Stickland
Colin Stickland
STEVE
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
