Hp director does not open when i click on the icon
Posted by david87239 on
Anonymous
    Novelist:
  • 136 Answers
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
2-Without navigating to another open window, press Alt and Space bar at the same time.
The Shortcut menu displays near the top-left corner of the computer.
Figure 1: Shortcut menu
If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
3-Select Minimize from the Shortcut menu.
HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen).
If HP Director does not minimize, click Minimize again until it does.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Posted on Nov 30, 2009
1 Related Answer
Anonymous
SOURCE: HP Director is missing
I know this may not be yours or anyone’s exact printers but the fix should be the same, what ever is the current model for you printer download that software and install, with your printer USB cable disconnected. I have a HP PSC 1210 all in one printer with director and drop down menu problems. My son was having printing problems, ink, with his 1610xi so I loaded a full install of the software from HP for 1610xi with all printers disconnected followed through with complete install, check box install without connecting, and restart computer. After computer restart complete I plugged in my 1210 instead of the 1610 the software picked it up and everything worked with more options than I had before. It works great. I reset IE7 under tools, advance settings, reset just to make sure everything’s cleaned up. I also clicked update in director and everything updated. Just follow the prompts during the install such as overwrite, yes, delete unnecessary files, yes. All newer models of the same type of printers have the older model drivers in the program. Suspect, for example if such as mine, with 1610xi software installed all earlier HP PSC ALL-IN-ONE Printers drivers are in the program. It's like getting a free software upgrade you will love it. Must download full install version though. I an sure this will help all.....
Posted on Apr 10, 2008
I accidentally deleted my hp director icon from my computer i dont know how to restore my hp director
If you have just deleted the icon from desktop and not uninstalled then we can put a shortcut back on desktop
Click on START button
click on MY Computer
OR
Open MY Computer icon from Desktop
Open Local Disk C:\
Open Program Files
Open HP Folder
Open Bin Folder
You will find a file by name HPDIREC
Right click on the file name and Click create shortcut on desktop ( this icon will not look exactly like the HP Director icon you deleted )
Close the window and you will find the HP Direct icon on desktop
If not, you can uninstall the software from Add/remove programs under control panel and install the latest software for your printer. Click on the download button below to open HP website to download the software by selecting your operating system
Download
*Note : HP Director is not longer designed by HP. IT is replaced with a new Software called HP Solution Center
Oct 21, 2010 | HP PSC 2210 All-In-One InkJet Printer
Used to print fine, however, recently, has become EXTREMELY slow, also, when tried to go to HP Director to check setting, will not open?
This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper.
Follow these steps:-
  • Click Start , point to Settings , and then click Control Panel.
  • Double-click Printers and Faxes .
  • Right-click the appropriate all-in-one, and then click Printing Preferences .
  • Click the Paper/Quality tab and under Type is select Plain Paper .
Have a nice day...don't forget to rate the solution.
Feb 19, 2010 | HP Photosmart 2710 All-In-One InkJet...
Don't have HP Director icon on desktop, go to programmes and don't have full complement, only 2 choices???
double click my computer-> open c:/->open programme-> open hp folder->then select the icon which u want on desktop -> r/c and sent to desktop.
Jan 31, 2010 | HP PSC 2410 All-In-One InkJet Printer
Hi There! I am having problem opening my hp director program
  1. Open HP Director using one of the following methods:
    • From the desktop : On your computer's desktop, look for the HP Director icon (c01425509.gif), and then double-click it.
    • From the Windows taskbar : Click Start , click All Programs , click the HP orHewlett-Packard folder, and then click HP Director .
  2. Without navigating to another open window, press Alt and Space bar at the same time. The Shortcut menu displays near the top-left corner of the computer. Figure 1: Shortcut menuc00833293.gif If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
  3. Select Minimize from the Shortcut menu.HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen). If HP Director does not minimize, click Minimize again until it does.
  4. Click the HP Director icon on the taskbar . The software opens and functions normally.
Dec 08, 2009 | Microsoft Windows XP Home Edition
HP director will not open
try this...
click start
right click my computer
properties
hardware
device manager
?ports
scan for hardware changes
Jan 06, 2009 | HP ScanJet 3500C Flatbed Scanner
HP Director won't open. I am on XP and IE7
HP Director has a flaw and is not compatible with IE7
I have a psc 1100 and I had to update my software from HP
CHECK THIS OUT
Go to HP, this link, type in your printer model #.
It still may fail to show...if it does not show HP recommends this
work around.
Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Apr 30, 2008 | Computers & Internet
HP PSC 1315
If the patch or the updates did not work on the link I sent you try this Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
Mar 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Director
Try to open the HP director from
Start >> All programmes or programmes >> HP >> HP director
Else reinstall the printer software.
Mar 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp director
It could be about this: I had same problem until I found a review somewhere - even HP technical support was totally useless - until HP FINALLY decided to up date its drivers to account for my/many people's downloading of Internet Explorer 7. As this is now done, and you cannot easily uninstall IE7 and go back to IE6: try again (1) HP Director and if not (2) I think update drivers or (3) uninstall / reinstall. Hope it helps.
Apr 04, 2007 | HP PSC 2410 All-In-One InkJet Printer
Computers & Internet Logo
329 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
