HP Pavilion dv6000z Notebook Logo
Posted on Nov 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fan shuts off on computer startup, led lights are
Fan turns off and on during computer startup, led lights are lit, screen is blank, happens about 9 out of 10 start ups
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
3125
Points
17
You need to clean the fan of your a laptop, or replacing that with new one.
Fred Yearian
Level 3:
  • Master 5,603 Answers
Fred Yearian
Master
Level 3:
Answers
5603
Questions
Helped
2248124
Points
16162
The fans are USUALLY controlled by the processor chip reading its internal temp and running fans as needed. Under the varying load during boot, it is not uncommon to have fans starting and stopping..
1helpful
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dv7-3080 will not startup. Power light is on,
Hardware problem, motherboard defect. Laptop Repair Shop can fix that.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Proffesional Services
09126888500
Screen only turns on randomly during start up, led lights are lit, laptop sounds like it wants to turn on and stops, then tries again, then stops. Problem happens about 9 out of 10 start ups, and when it...
remove battery, press and hold power button for 5 seconds, then wait 5 minutes, put battery back in securely and try again. If it powers on, try and look at the power meter to see if it is registering the power supply. You could have faulty memory chip or faulty power supply
Monitor /keyboard will not come on when computer boots, monitor light never turns green and no leds lit on keyboard,know both items r working tried on different computer and both work.Also processor fan is...
did u check the ram? please pick out RAM and placed in next slot. i will happen due to failure in RAM. is there any beep tone? ok
check your RAM.
i hope that is the problems of RAM
Clarify the problem of blank screen
sounds like the display/cable or the port on the systemboard failed. please call toshiba support http://www.toshiba.com/tai/support/support_cons.jsp
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
