Question about Motorola Mobility H700 Wireless Headset
Caller unable to hear me while using the H700 headset.
Hi. I've owned a H700 headset for about 18 months. Lately, the caller on the othe end can barely hear me. The headset is fully charged. Is there an internal battery that might require replacing on the headset?
    New Friend:
Hi there , to solve this proble since you have the headset over 18 months you need to change the internal battary the life time for these handset battery up to 24 months try to replace it by take it to cellphone shop and im sure you be happy.
Posted on Dec 18, 2010
6ya staff
SOURCE:
My H700 bluetooth, I can hear caller but they can't hear me!
The average life of a Bluetooth Earpiece is usually a few years. When you are having symptoms like you are describing it usually means that the Blutooth headset is at the end of its service life. You might want to cintact Motorola and see if they will Warranty them.
Aug 22, 2012 | Motorola Mobility H700 Wireless Headset
My bluetooth wont let othe people hear me but I can hear them can u tell me whats wrong?
You've probably muted them by accident. Try pressing both volume buttons simultaneously - it should unmute.
Mar 07, 2010 | Motorola Mobility H700 Wireless Headset
H700 is paired...I can hear the caller but they can not hear me? Any help would be appreciated.
I actually had this same problem within the 1st year I had my H700 headset. I had to carefully pry open the flip end and remove a small piece of fabric that had been put inside by the manufacturer. After I had done this, everyone I talked to when I used the headset could hear me just fine. I am not really sure why it worked since all I did was take out a tiny piece of black fabric but it seemed to. I was able to also close the flip end back up as if I had never opened it and it still stays closed. I have still been able to use the headset even after about 5-6 months later but I did get an extra headset to have around if I need it.
Sep 29, 2009 | Motorola Mobility H700 Wireless Headset
Volume delay when used with iphone
Unfortunately, this is no correction for this, as bluetooth is still a pulse device, this delay is a communication problem and will not be corrected soon.
Apologies for our lacking in electronics. :(
Hope this helps.
May 07, 2009 | Motorola Mobility H700 Wireless Headset
What tells when fully charged?
On the Motorola H700, the light will turn from red to green.
link to your online manual
http://www.motorola.com/mdirect/demos/how2_h700/main.html
Good Luck
Jul 14, 2008 | Motorola Mobility H700 Wireless Headset
Problems w/H700 bluetooth
Try taking a small needle and gently clearing out the mike hole near the end of the boom. Anything I am outside and sweating a lot mine will clog up and I have the same trouble until I clean it out and then it's fine. Do not insert the needle in very far, all you need is to clear the outside opening a bit.
Jun 20, 2008 | Motorola Mobility H700 Wireless Headset
H700 is paired to phone and computer but will not connect
make sure your bluetooth function on your cell phone is on then if this doesnt work delete this device from your phone an reinstall it
Jan 11, 2008 | Motorola Mobility H700 Wireless Headset
Cannot hear callers/callers cannot hear me/buzzing & crackling sound when connected
try pairing the bluetooth device to another phone, i had the same issue, i used a different phone for testing. it works, so i paired it to my phone and it also works
Dec 12, 2007 | Motorola Mobility H700 Wireless Headset
Was working fine until now.
uninstall device and try to reinstall if this doesn't work go to www.n1wireless.com about 30 bucks
Dec 08, 2007 | Motorola Mobility H700 Wireless Headset
Problem with Motorola H700 Bluetooth
rhondarenee: If you're using a Motorola RAZR V3, the problem is the cell phone. Also check the volume buttons on H700 that sometimes it goes the volume all the way down. It is a common unnoticed situation. SithPitt
Jul 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
233 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
