Sony BRAVIA  KDL-40XBR2 40 in. LCD HDTV Logo
Posted on Nov 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
40xbr2 bravia kdl sony LCD tv. The screen shuts
40xbr2 bravia kdl sony LCD tv. The screen shuts on and off randomly on all video(cable dvd,s playstation). I have tried the factory reset and still the same problem. Took the back panel off not much dust, TV was made in Aug 06 Help!
Anonymous
Level 2:
Sniper:
  • Expert 53 Answers
  • Posted on Jan 22, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
53
Questions
0
Helped
34395
Points
162
Problems relating to the automatic turn on and turn off of a set like this usually point to the main board being an issue. For this set, I believe Sony refers to that board as the "AU" board.
It's probably not the G/Power Supply board, especially if it turns itself on. Power supplies will turn a set off, but rarely--rarely--turn itself on.
If there's no kind of extended warranty involved here,
you could be looking at $500.00 for parts and labor to repair this kind of problem.
As always, try any software/firmware updates Sony might have available on their website prior to pursuing a repair visit.
1helpful
SONY BRAVIA KDL-40XBR2 faces look like cartoons
Tow possibilities. [1] The LVDS cable (the flat cable that connects between T'Con and LCD panel) loose contact at its connection sockets. Re-insert this very carefully, and check. [2] Fault to T'Con board itself. If so it should be replaced. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SONY BRAVIA KDL 40XBR2 color is fading. What is the problem?
Likely a bad circuit board= a photo of what it looks like posted here or elsewhere might help narrow down what the problem is.
SONY BRAVIA - 40 XBR .TV will not tune into digital channels. We get a blue screen with No picture and states No Event Information and also states MPEG U1
Hi Douglas,
First of all, thank you for purchasing the service/repair manual of KDL-40XBR2.
Please email me at [email protected], I will send to you the copy.
Again, thank you so much!
Have a great day!
Mjsazon
2helpful
3answers
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
I have a Sony DCD Recorder (RDR-HX780) and Sony 40" 1080P LCD TV (KDL40S510) "tripple checked lines and HD cable connection." Problem (which occurs randomly and is anoying): When switching to DVR or...
Try this: got to www.sony.com mouse over "support" then click on "drivers/software" enter your model #(s) and then you can check for firmware updates, the symptoms that you list, unfortunently are somewhat common when connected via HDMI cables.
Check for updates on both product that you list.
Good luck !
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
MANUAL
found them on line
Thank you
Bob
1helpful
2answers
Connecting old DVD player to LCD
Just respect the colors. Green output from the dvd to green input tv, Red output from the dvd to red input tv and the same with blue. All 3 cables (green , red, blue) are for the picture, so you got to plug another 2 for the sound.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
