Homelite 'Yard Broom' Leaf Blower Logo
Posted on Nov 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to find a replacement spring that actuates the diaphram activated fuel valve
Jeff Hagemann
Level 2:
  • Expert 430 Answers
  • Posted on Nov 30, 2009
Jeff Hagemann
Expert
Level 2:
Answers
430
Questions
Helped
251643
Points
918
Do you mean the spring under the lever on the metering side of the carb? A new lever, needle, and spring should be included in a complete carb rebuild kit.
Where is the EGR valve located?
Doesn't have or need an EGR valve it has Camshaft Position (CMP) Actuator System
The camshaft position (CMP) actuator system is an electro-hydraulic operated device used for a variety of engine performance and operational enhancements. These enhancements include lower emission output through exhaust gas dilution of the intake charge in the combustion chamber, a broader engine torque range, and improved fuel economy. The CMP actuator system accomplishes this by changing the angle or timing of the camshaft relative to the crankshaft position. The CMP actuator simply allows earlier or later intake and exhaust valve opening during the four stroke engine cycle. The CMP actuator cannot vary the duration of valve opening, or the valve lift.
During engine OFF, engine idling conditions, and engine shutdown, the camshaft actuator is held in the park position. Internal to the CMP actuator assembly is a return spring and a locking pin. During non-phasing modes of the camshaft, the return spring rotates the camshaft back to the park position, and the locking pin retains the CMP actuator sprocket to the camshaft. The park position for the CMP actuator and camshaft is 8.5 degrees before top dead center (BTDC), which is equal to 17 crankshaft degrees BTDC. The engine control module (ECM) can only command the CMP actuator to retard the valve timing from the park position, or advance the valve timing back to the park position. The total range of valve timing authority is approximately 20 degrees of camshaft rotation, which is equal to 40 degrees of crankshaft rotation.
CMP Actuator System Operation
The camshaft position (CMP) actuator system is controlled by the engine control module (ECM). The ECM sends a pulse width modulated 12-volt signal to a CMP actuator solenoid to control the amount of pressurized engine oil, into the CMP actuator. To regulate the pressurized engine oil into the CMP actuator, the solenoid uses electromagnetic force on the solenoid pintle to pulse the oil control spool valve. The pressurized engine oil is sent to unseat the locking pin, and to the vane and rotor assembly of the CMP actuator, to either retard or advance the valve timing. The ECM will control the amount of ON time applied to the solenoid.
How do I replace and install a fuel filler door actuator on a 2007 Hyundai Santa Fe?
if you activate the button and you can hear the release working it will be the flap spring at the flap hinge
they are a simple V shaped spring and they break and fall out
without it the door flap is not moved and the actuator just reengages the flap
Locate fuel volume regulator 1999 honda civic
EFI fuel pressure regulators come in various shapes and sizes but their purpose is the same- to hold the fuel pressure at a certain differential above the intake manifold pressure. The inner mechanism usually consists of a sealed diaphram chamber, a spring, a diaphram, bypass valve and a manifold pressure reference port. The valve is connected to the diaphram and the spring pushes against the diaphram from the manifold pressure side. The spring pressure determines the static fuel pressure. If there is vacuum on the port, say at idle, this reduces the effective spring pressure acting on the diaphram and reduces the fuel pressure under vacuum conditions. If there is pressure on the port, such as under boost, this effectively increases the spring pressure, thus fuel pressure.
Most OE regulators use a one to one ratio. At one psi of boost, it would add one psi of fuel pressure. This way there is always a constant pressure differential across the fuel injector. Most regulators have a static pressure of between 38 and 44 psi. The fuel pump always puts out an excess of fuel volume. The regulator controls the pressure in the fuel rail by bypassing any fuel not used by the engine back to the fuel tank once the control pressure is met. At idle, perhaps 95% of the fuel delivered to the fuel rail is returned to the tank. At full power, perhaps 5% to 50% of the fuel delivered is returned back to the tank. Fuel is generally routed from the pump to one end of the fuel rail which feeds the injectors. The regulator is usually mounted on the opposite end of the rail. This arrangement allows any hot fuel in the rail to be immediately purged back to the tank after a hot start to reduce vapor lock and fuel boiling. A similar arrangement should be used if you are fabricating your own fuel system.
Rising Rate Regulators Some aftermarket companies produce fuel pressure regulators which have a ratio of higher than one to one. These are intended for use mainly on engines which were not factoryturbocharged. Because the fuel injection system was never designed or mapped for the increased levels of airflow, fuel flow and manifold pressure, these regulators attempt to supply increased fuel under boost by vastly increasing fuel pressure. This is a bad idea for several reasons:
1. Fuel delivery varies as the square of the fuel pressure so you need 4 times the pressure to double the flow, say 160 psi in most cases.
2. The fuel injectors, hoses and fuel pumps were never designed to operate at this pressure. Pump life is severely reduced, injectors may not operate properly leading to a lean out condition and a component may fail causing a fuel leak and fire.
3. Fuel delivery under boost is now under the control of a mechanical device rather than the ECU so mixture control is crude at best.
The proper course is to use a system designed for turbocharged operation with appropriately sized injectors for the job. The OE regulator in most cases is well capable of controlling the pressure and because you can flow a lot of fuel through a 5/16 hole at 40 psi, they are entirely adequate up to 500 hp in most cases. There is no need to install larger fuel lines or massive regulators for most applications. Most aftermarket regulators are not required and a waste of time and money for street applications. They might be required at extreme hp levels on race applications or those using methanol where higher fuel flow rates demand larger lines and regulator passages. The fuel pump may have to be upgraded if the power levels are increased substantially over stock however.
1helpful
I rebuilt the zama carb but it will not run for more than 30 or 40 seconds what did i do wrong
There are plenty of things you may have inadvertently done wrong, start first by checking fuel to the carb, replace the fuel filter in the tank, check the fuek hose up to the carb for signs of leaks, if all ok, re check the carb, on the pump side it is very importent the diaphram goes against the carb body followed by the gasket and the cover, this is because there will be two small flaps on the diaphram that act as non return valves, so must be against the carb body, there will also be a filter under the diaphram, this should be replaced, on the metering side of the carb it is very importent that the gasket goes against the carb body followed by the diaphram and cover, this is because the gasket is used as a spacer if not there the diaphram will be too close to the metering lever and it will flood, under the diaphram will be the metering lever, needle and spring, make sure this all moves smoothly, the metering lever should be level with the sides of the carb body, there will also be core plugs pressed into the base of the carb, these will be covering the jet holes, dirt can accumalate under these, however you need to pearce the plugs to remove them, and replace with new.
I need to know which fuse controls the fuel pressure relief valve.
fuel pressure relief valve is not controlled by a fuse its controlled by spring pressure against a diaphram that is set to a specific pressure to control fuel pressure.
Well its not really the fuel tap that im looking to change but the diaphragm need changing so can someone explain to step by step to changing the the diaphragm?? and do i need a special silicon or oil to...
Hi Im not 100% certain what the hyosung diaphram looks like, but most are held in with 4 small screws holding the plate where the vac line goes. There will be a spring and plunger activated off the centre of the diaphram. This should come with the new diaphram.
You will need to remove the fuel tap first, or have the tank upside down on something soft.
You are only dealing with a few screws and a couple of parts, so just go slow and remember how it came apart.
a thin smear of rubber grease my help fit the new diaphram, do not use silicon, it can stop the diaphram moving and is not petrol proof
7helpful
I bought a Vigoro deluxe water timer last spring, it worked fine all summer. This year I can't seem to get it to work, I hook it up to the spicket and the water runs thru the whole thing and in on the...
I had the same problem with several of mine. So I tore one apart. The problem isn't that the valve doesn't close. The valve uses a rubber diaphram that flexes in and out, sealing off the water supply. The rubber diaphrams develop cracks, allowing water to pass through the valve. The rate of water flow depends on how large the crack is. The crack will become larger over time as the valve moves the rubber diaphram in and out. The diaphram can be easily replaced. However, these units are not designed to be taken apart and repaired and I can't find a replacement for the diaphram. The bottom line is that once the diaphrams crack (and my experience is that they all do within 1-2 years-time), you have to throw it away and buy a new timer.
Jun 14, 2010 • Garden
Engine starts but immediately quits.
Check the float or needle and seat valve inside the carb. One of those is probably stuck. If its a vacu-jet carb then check the diaphram on the side of the carb. It would be a small plate held on by 2 to 4 small screws. A stiff Diaphram means that it wount pump fuel.
1988 Jeep Cherokee
Please check the EGR valve, located on driver's side of engine below intake manifold. Inside of the EGR valve is a diaphram pushed out by a spring. The spring rusts away, leaving the diaphram in the wrong position for idling. I have stretched out the spring, or just replaced the valve and had good luck thereafter. Valve is round about the size of a pop can (diameter) and shaped like a UFO.
Fuel tank
THERE is a valve on truck I believe it is called the switching valve.all the fuel lines run into it. when the switch activates pump in the tank this valve has a diaphram that the fuel pressure moves it . this valve is bad. i had this same problem once before and replaced it will be a black canister looking unit on frame with around 4 fuel lines going to it
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
