The missing items in the menu correspond to the Add-On applications Geometry, Picture Plot, Conversion, Physium, and ProbSim.
You must download them from the Casio website and transfer them to the calculator. Download also the Add-On installer and follow the instructions.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Hello - aldarroch: You must be running Windows 2000/XP/Vista, Mac OS9.0 or later, have the software and cable provided with the camera to download images to your computer. From your statement that you have "no disc" to download pictures I take it that you don't have the needed software. Unfortunately Vivitar, unlike most camera manufacturers, doesn't seem to provide easily available software for download. I suggest you email them requesting the software or phone them toll free for the info from the contact information available on this PAGE. If I've misunderstood your problem please come back and restate your problem with more details about what you're missing. Good Luck, Mikeywaf
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Consider NOT using the USB connection. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
