Having sound problems. Down loaded propix years ago on a computer that crashed. Now down loaded on my newer computer, good video, but no sound when trying to capture, haven't been able to find any info, tried diagnostics and every thing propix, and windows manuels reccomend, still no sound.
  • 733 Answers
Reinstal the driver is the only way
Posted on Nov 30, 2009
6ya staff
SOURCE:
XFX 6850 crashes
Had the same problem, video card went bad. Replaced with newer faster model.
Jun 12, 2013 | Computers & Internet
Can't initialize sound engine error code 23 I already have so, it was two years ago, reinstalled windows, now began again ((( please help
The loaders for this device cannot load the required drivers. (Code 23
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Mar 12, 2011 | Computers & Internet
Maybe you can help me out with a problem I am having with our monitor. It?s an HP 2159m LCD monitor?.we just bought it last year. A couple weeks ago, I turned our computer on (it?s a desktop)?.and the...
Please check the video connections to make sure they are secure.
Some devices have the connections hanging straight down, and gravity works all over the planet.
If you have another monitor available, plug it in and check the computer's video output with it. If you get a picture with the alternate monitor, then you know the original monitor was the culprit.
It really does sound like a loose connection, but would not be surprised, you past the one year mark... that is when warranties expire.
good luck and don't forget to vote!!!
Sep 28, 2010 | HP 2159M Monitor
Video game shuts down no error report at all
Go to your System(in Control Panel) and check if you have Service pack 3. If you have SP2, download the SP3!!!!
Dec 06, 2009 | Video Game Consoles & Games
Apple ibook crashed when on MS Word. Black screen fan running???
Sounds like you have a problem with the logic board. This appears to be a common problem with iBook G4 related to the fit of the logic board (ie motherboard) within the case.If you were to take it to apple store the likely fix would be to replace the entire logic board which is very expensive and probably not fiscally sound on a 5 year old machine. Another option would be to try to fix it yourself. If you are feeling brave you can dissemble the laptop and attempt to shimmy the logic board back into position.
Here's a link that detail the approach. http://www.coreyarnold.org/ibook/. This guy had success on two ibooks that had the same problem and they have been working for 2 years since he did his repair
Also, here is a link to a forum that may offer you a few more approaches to solving your problem. iBook G4 won't boot up - fan running & black screen - AppleNova Forums
Hope this helps, good luck!
Mar 30, 2009 | Apple iBook G4 14-INCH Series M7701LL/A...
Computer that had my purchased turbotax crashed before using need to download on new computer having problem
go to turbotax.com and you may be able to down load turbotax for free. good luck.
Feb 01, 2009 | Computers & Internet
My Dell Dimension 4500 XP has no Sound
i) i would suggest you to format ur system or reload OS or reload OS Freshly(dont mess with crashed system)
ii) then try load sound drivers from the mother board CD that came with ur computer which will have video drivers, sound drivers, network drivers......
Dec 27, 2008 | Dell Dimension 4500 PC Desktop
CameraMate ProPix DVD is freezing
you need to download driver Cameramate_2.29 from the internet
Dec 10, 2005 | Zio Corporation CameraMate VideoSafe...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
