Question about Sony Grand WEGA KF-42SX300 42" LCD TV
Turning on green light starts flashing only to hear a click and then the red light starts flashing... tv will not come on.. i can hear a fan that seems to start up...
Posted by heybrody on
Steve Allison
  • Sony Master
  • 5,569 Answers
The power up sequence is being interrupted and this could either be the main power supply or a protective shutdown of the supply because of a downstream failure. The clicking you hear is the activation and dropout of a relay.
If the flashing seems to be in a pattern, it may be telling you what has failed via the coded flashing. Any Sony service (or service tech) can tell you what the problem likely is if there is a pattern to it.
Posted on Nov 29, 2009
62hmx95, blinking light, powers on then off
Examine in order the lamp, the ballast, the fans.
Apr 29, 2012 | Toshiba 62HMX95 62" HDTV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Hello, I have the KDS-R60XBR1 60 inch TV. The green light flashes about 40 times and then the red light flashes about 10 times (then nothing). When the green light is flashing, you can hear the TV trying...
First, if you have the manual, open it to troubleshooting, if you don't have it; www.sonystyle.com then click on support, then manuals. you can download it for free. The manual will decipher the flashes for you to narrow down your possibilities. The three main problems in the Sony lineup are the optical block, the bulb, and the fan. The fan is the only real obvious one that can be fixed quickly. When you turn on the TV, the fan should click on ( may vary depending on your main setup from TV menu) However, if you have any compressed air (dust off) etc. The fan is on the rear of the set on the right lower 1/3rd (looking from behind set) Location is in the manual too. If the fan can't turn on, the TV will shut down. Also, go to this site for further help from "Sony"
http://sites.google.com/site/sonylcdrptvproblems/#TOC-Optical-block-problems-by-TV-model
Hope this helps. If you need further help, post a comment and I will help you further.
Sep 27, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Telly on but no sound orpicture
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
Apr 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Grand Wega KFE50A10 has a black screen. When started the power/standby light flashes green and the fan starts. After a period the same light starts flashing red in blocks of five. What does this...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2400 you can find it here:http://www.discount-merchant.com/Sony-XL-2400-Lamp-F93087500-Bulb-A1129776A-p/sony_xl-2400_f93087500_bare.htm?Click=48173 .Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
The problem is after the green light stops flashing I push power button and before the tv starts up I hear a click and the status light starts blinking red in solutions James
I would check the fans in the back of the tv are all coming on there are three of them that is a common issue when you get sudden shutdown after start
Jan 25, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Sound went out, tv turned off, red light flashing...
The Lamp being bad as well as one of the three fans in the unit not turning could also cause the problem.
Hope this helps,
Skyassoc
Jul 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV won't turn on
you need to replace the lamp in your tv, it is easy and you can do it. Look on the sides of the set for a door labled lamp, with the set unplugged open it up and remove the lamp, if the bulb is out it will have lots of glass in the lens
Jul 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Sony Grand WEGA KF-42SX300 42" LCD TV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
