Toshiba Satellite Pro 6000 Notebook Logo
Posted on Nov 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba satellite pro 6000 power
Have a toshiba satellite pro 6000 which when turned on flashs 3 lights which are the hdd sd and power lights then turns back off and shows a orange on the dc in light. and will no do any thing else. please help.
bob chang
Level 2:
Novelist:
Champion:
  • Expert 226 Answers
  • Posted on Mar 11, 2010
bob chang
Expert
Level 2:
Novelist:
Champion:
Answers
226
Questions
0
Helped
50888
Points
367
Sounds like a bad motherboard to me - assuming that it has memory installed.
  • beth_pearceu
    beth_pearceu Apr 20, 2014
    I replaced the battery and charger on mine and then it was ok.
Toshiba Satellite C850-13E both power lights flashing
verify that you are using a tobisha power adapter that is for this computer. blinkng light are normal associate with wrong voltages
Satellite pro L300 screen is blank. Power light is on (green), battery light is yellow, HDD light is off.
Sounds like it's broke. Blank screen means it's broken, battery light is yellow I beleive it means time to replace the batteries.
2answers
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Green led mains light comes on, battery amber light rapid flash
          This sounds sucky, but you may have a power-supply issue. Especially if you have had to repeatedly press the power-button. If the laptop is new, call Toshiba and see if it's under warranty. If not, find a local computer tech to test your power-supply. This problem is less common nowadays, but still an issue for some!
          Hope this helps!
          -- RT
          3helpful
          Does the Toshiba Satellite Pro 6000 have a
          The Toshiba Satellite pro 6000 doesn't have a built in microphone as far as I can remember but it does have a microphone socket at the front next to the headphone socket. Both sockets are on the bottom left hand side left if looking from the front. The microphone one is the one on the left, if you look closely there are symbols next to each of the sockets, one looks like headphones the other like a microphone.
          Hope that helps
          Chris
          Hdd error
          Hai,
          Your hard disk is having some kind of mechanical problem.
          Best solution for this is when it boots up, back up your important documents to a pen drive or CD and go for new HDD.
          good luck
          Rabby
          Display problem
          Dear H duke,
          please download the driver for Toshiba Satellite Pro6000 from this URL:
          http://www.driverfiles.net/Notebooks/Toshiba/Satellite-Pro-6000/download/page,sh,31302,221,19,.html
          maybe this will help you.
          Takecare
          Akshay
          14helpful
          4answers
          Problem with mass storage controller's driver
          I was able to find drivers for this device which turns out to be an SD Card reader built into the laptop. Here is the site I found it on: http://www.toshiba.com/tai/support/support_cons.jsp
          You'll want to click on "Computers and Accessories" on the left hand side, and then select "Laptop Computers".
          Upon selecting the correct model, I found all the pertinent drivers for my laptop.
          The Category, which is the middle column on the drivers page, is going to be something along the lines of "Driver Flash Memory SD"
          Good Luck!
          Top Toshiba Computers & Internet Experts
          ExpressFiX
          ExpressFiX
          k24674
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
