GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
I have a GE 52 " rearprojection flat screen picture TV 4 years old. The color conveyance is off and it will not realign using the remote. Help!!
Posted by kmaness5 on
Sonny Berry
  • GE Master
  • 8,617 Answers
If the convergence option is still visible under the picture settings in the menu. Then the problem will usually be related to the convergence power supply board, which is the board on the far left which is suspended over the main chassis. You can get the convergence power supply board, or have yours repaired at www.tvrepairworld.com
Posted on Nov 29, 2009
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Picture colors are seperated on my tv. the sound
Hi i did not want go to far whit this//
usely you will have to replace the convergence module there are 2 stk ic on it,and then use the magic focus button on the front panel/ if it not fix back your color alignement you will have to do manually whit the remote control.
but that needs some experience to do so...
hope that help ,its give a idea
have a nice day
GE 52 " rearprojection flat screen picture bowing 3d effect
Thats usually a very easy repair by replacing FL231, DL231 and CL230 total parts are about 11.00 at the following link and they provide free instructions. The components are all listed under RCA parts category.
http://servicemanuals.vstore.ca/
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
No picture -- white screen -- no sound
With no video and the the colored stripes, it sounds like the LVDS cable needs to be reconnected to the LCD control board or the control board itself is bad. If the unit is only 3-4 months old, it should be covered by warranty
Whats wrong
Call or email the BBB and report GE
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Screen seems to flip
All the symptoms in your tv point to a convergence problem,the unit has 3 amplifiers one for each color,this amplifier IC's need to be replaced and then realign the colors,sometimes just by replacing the Ic's you are able to realign the color with the remote but sometimes they need to be realign from the service menu. You can identify the IC's because they are mounted in heatsinks and by its marking,in the front they have STK--- ---,6 numbers after the letters,their size is about 2.5 " long and 1.5" wide with a row of pins solder to the main board.If you are familiar with tv service this information will help but if you are not too familiar be safe and call for assistance from a servicer.
Top GE Televison & Video Experts
Jaime Hernandez
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
