Is this a brand new system? If so, maybe components not correctly seated inside, ie CPU or memory not seated correctly.
If this isn't a new system then in my experience it is most likely a power supply or motherboard issue. Hopefully power supply as this is normally the cheaper component of the two!
Hope this helps.
Testimonial: "I was hoping it was not the motherboard due to the cost of a new one being as much as a new pc. You input was helpful though. Thanks."
I agree with the previous post. First open the case with the unit plugged in to the wall. Before you put your hands inside, unplug the power plug. This will ground you to prevent electromagnetic shock to the components. Next with two thumbs remove and re-seat the system RAM. One or both chips can creep out of the socket. Experiment and start the pc with one chip and then the other in case one is bad. If the RAM does not fix it, any short will prvent the pc from booting. While you have the case open, Remove all add in cards. This includes, modem, sound, network, video, etc whether it is a PCI, PCI-express, or AGP socket, When powering on you should then get a beep for video missing. Replace the cards one at a time until it quits working. AS the last resort I would replace the power supply. To replace it you need to tell us what name brand, model, or open the case and copy down the name model and power in Watts it uses. You may find this video helpful http://www.youtube.com/watch?v=DLxNPBQBfT8
I bought the system new at BestBuy the day before Windows Vista was released to the public, so however long ago that was... The issue with the fans continuing running was starting up several weeks prior to the fans running all the time now. I could turn the system off and then back on a couple of times in the past and it would eventually power up and work fine. Not the same now. Does not power up at all.
