Question about Canon EOS 400D / Rebel XTi Digital Camera
I am having trouble photographing birds. Do I use the telephoto lens or the wide angle lens? I also have a macro lens for my Canon EOS 400D SLR Also what settings do I take them at. I have a tripod but the birds are too quick so they have to be for hand held. I am finding that when taking them with the telephoto lens they are not sharp and the background is blurred and not good. Thank you Val
  • Anonymous Nov 29, 2009
    Thank you for your reply . I am glad I was using the right lens so my settings must be wrong. I used Auto mainly Should I use a different setting, ISO , shutter speed etc. Thanks Val
Anonymous
    Brigadier General:
  • 4,090 Answers
Use the telephoto lens.. wide angle will tend to distort the image and provide too much detail( distraction) around the object of interest. Bird pictures become more interesting when they are mainly of the bird. So when you look through the lens, zoom up to the bird to the point where you have it nicely framed with none of its parts outside of the frame.
Capture the whole image.
Wide angle lens is mainly used for scenery or where you want to take a group photo or panorama.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 29, 2009
Testimonial: "Thank you for your help. Do you have any suggestions as to what settings ie Automatic or AV etc and also the ISO, shutter speed etc, Thanks"
    Helllo again,
    Using AUTO is fine, but read your manual and set up the ISO in accordance with the light that is available and the speed etc.
    If you want to photograph a humming bird I would manually turn your ISO wheel to the highest setting say 5000 or whatever is close to that. The higher speed will freeze the subject in flight.
    If it is very bright light then a larger number aperture ( smaller hole) say F16 or F22. If it is overcast or dim light smaller numbered aperture F8.
    as long as you set your ISO for what you want in relation to the speed of ther object and the average light , the auto should select the appropriate aperture.
    if you are in a darkened situation for photo shooting owls then the ISO should be set to a lower value 64 or less
    This type of manipulation is called pulling and pushing.
    On film back in the dark ages if you had a film marked ASA64 and you went into a cave to film you could crank up the ASA to ASA300 and get photos that would not normally develop.as long as you told the developer that it was 'Pushed". They would treat it differently in process and you would have pictures not generally available on that level of ASA.
    It might be better to get a book on Digital Photography and read some of this material... Its not complicated.. and it makes for good shots you can win money with and even enter competitions.
    Good luck, always be willing to experiment.. digital is less exoensive and far mor instantaneous than film was
    Dennis
    Nettiser Australia
Own DSLR camera would like to know the single best lens for the DSLR?
"Best" lens depends on several things:
1. What kind of pictures do you intend to take?
2. Do you mind a heavy leans? Some are 10 pounds or more.
3. Your budget.
The "standard kit lens" that most come with is perfectly good for general photography. If you want to take architectural pictures, you'll need something different. If you want wide landscapes, you will need a wide angle, and if you want wildlife/bird pictures, you'll want a telephoto lens. It all really depends on what you intend to do...
For example, I have a very wide lens I use for interior architectural pictures, medium telephoto for portraits, and a variety of long to very long telephotos for wildlife pictures...
Yes, there are some extreme zoom lenses that cover 'normal" to "very long" telephoto. They're expensive, not especially sharp, and very heavy. Everything is a compromise.
Dec 18, 2015 | Canon EOS Rebel G 35mm SLR Camera
Every picture I take has a line going through every picture
Have you checked you lens, there could be a hair line dust scratch on it. Or you have it set on a setting that helps with leveling...yes camra's do have them.
Aug 27, 2013 | Polaroid Studio Series .43X HD Wide Angle...
Does Sigma 70-300mm f/4-5.6 DG Macro Telephoto Zoom Lens fit canon eos rebel
Sigma makes their lenses with a variety of camera mounts. If you get the lens with a Canon mount then yes, it will fit any EOS Rebel camera body. A lens with a Pentax mount, for example, will not fit a Canon camera.
Nov 24, 2012 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Hi, I bought a CANON FD - 28 mm f 2.8 WIDE ANGLE LENS for my OH's eos 400D, he says it doesnt fit, its too small. Is there an adapter or anything or should I just look for the right one? Many thanks
Canon FD lenses date back to before the mid 1980's. They use a totally different mounting system to the later EOS mount which was a redesign to suit the needs of auto-focussing.
Unfortunately they are chalk and cheese: you cannot realistically fit an FD lens to an EOS camera.
Your fix is to sell the lens and to buy one with an EOS mount.
Jul 20, 2011 | Canon FD 28mm f/2.8 Wide Angle Lens
I just purchased a Sigma 2.8 f=28mm for canon but I don't know if it will fit my Canon EOS 500 N (same as Rebel G) 35mm SLR film camera. Can you help with this question.
Canon EOS 500N has an EF lens mount, so all lenses with Canon EF mount will fit. All lenses with MF and EF-S won't fit. If you purchased Sigma 28-70mm f/2.8 EX, then it have EF mount and will fit EOS 500N.
Jun 06, 2010 | Sigma Zoom Wide Angle-Telephoto 28-70mm...
I have a Cosina AF Macro 100mm lens that I used on
you should be able to use that lens with it. As long as it attaches to the SLR body ok. The thing to be aware of is with better technology in the newer camera you may have AF issues with that particular lens.
May 08, 2010 | Canon EOS 400D Digital Camera
How to attach wide angle lens to telephoto
I don't understand your question...a wide angle and a telephoto are two different lenses.
Nov 12, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
I want to add lens to my fujifilm s5600 to take better pics
There are lenses available to add with an adapter ring. I have the wide angle lens (which I LOVE) and a 2x telephoto lens. The wide angle lens allows me to macro from several feet away. It is an amazing lens. The telephoto lens is something you really need to use with a tripod. But yes, there are lenses you can add to your camera.
Dec 16, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
How to fis additional lens for canon power shot S1 IS
On the lower right side of the lens (as viewed from the rear) is a small button that releases the ring around the lens barrel. Removing the ring reveals a bayonet-style mounting flash that allows you to attach a lens adapter for extended telephoto, wide angle, or macro capabilities. Visit your photographic stockist for info on what is available
Apr 23, 2008 | Cameras
Telephoto lens
Hi, the adoptor tube are not compatible to the camera try to consult nearest lense seller they can recommend the exact adoptor lenses to your camera.
Sep 28, 2007 | Canon PowerShot Pro1 Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
