Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly. The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted. Mine, I just unplug it from the USB and plug it back in to reboot the software. If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN Click 'Open Menu' From 'Tools; navigate to, and click, 'Audio and Video setup' Set your speakers Click 'Test' - if OK, move on. Set your mic as default Use the slider to set volume and test. Click 'Next' This takes you to the video setup Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN Use 'Webcam Settings'to fine tune the picture. Click 'Finish'
First uninstall your msn messenger and then uninstall then webcam software/drivers.After that reinstall the webcam and then reinstall the msn messenger. This should fix the issue.
If the web cam is working normally with other web cam applications but MSN then it's required to configure MSN to use the web cam. Please follow the steps given below to configure MSN to use the web cam.
(i) Please ensure that the web cam is turned ON. (ii) Then, double click the MSN icon and log on. (iii) Click on the Tools menu, then click on the audio/video tuning wizard. Then, click Next to start the wizard. (iv) On the first wizard page, under Camera, click the web cam then click Next.
Performing all the above steps will configure MSN to use with the web cam. In order to start a video conversation, follow the steps given below after signing in MSN: (a) Click Action, then point to audio/video. (b) Then, click start a video conversation. (c) Select a contact from "My contacts" page then OK.
Open msn Plug webcam in Click (>) show menu > tools > audio and video set-up > run through mic and speaker tests > next > set your camera as defaut and adjust settings > finish
as ive told others, make sure u actually turn off the software program that came with the computer before using with msn! u should be able to have it on while using it but for some reason some computers wont allow it! it "tells itself" that there are 2 programs trying to run the web cam when really only one is. but because the program is on, it sees it as being used in 2 places at 2 different times!
try turning off and exiting the software (dell webcam manager) and then go onto msn and try using ur web cam!! make sure the dell manager is exited, then when u have a msn window open, turn the cam on and see if ur friends can see u then..
good luck.. if this doesnt work ill check back and see what i can do for you!
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”. Next go to the Menu Bar on right side, click on Action. Go to “TOOLS” and click “Audio and Video Setting and follow the instructions.
please let me know if this has solved and don't forget to rate
your cam also needs setup on your messaging program
yahoo cam setup Go to Messenger at the top left and click on it. Next go down to Preferences and click on it. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card. Next go to the Test Audio section and in blue writing click on “Open the call setup assistant” and follow the instructions on the left window let me know if this helped
your cam has to be setup on msn as well After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”. Next go to the Menu Bar on right side, click on Action. Go to “TOOLS” and click “Audio and Video Setting and follow the instructions.
everyone has this problem have you set the cam up with msn
try this first and then let me know
let me know if you still have a problem
PLEASE don't forget to rate me
