Some players will only play back DVD-R .. some only DVD+R .. many older ones wont play DVD rewritables at all...
DVD+ and - R recordings have lower contrast than purchased factory DVDs .. so if the laser in your mustek has a bit of dust then that will first effect computer written disks .. you can get a cleaning disk .. those have little brushes that brush off dust from the laser lens .. more likely though if your mustek is an older type, that you have to use DVDs that are compatable with it .. while DVD+R is the better format .. most older DVD players are compatable with DVD-R ... so thats kind of the standard that works in most players .. however there are a few exceptions .. most newer equip will play either, even rewritables ...
It is the re-recordable version of the DVD+R
and everything that was said about the DVD+R is valid for the DVD+RW. Only the
newest DVD players play movies recorded in disks using this format. There are
recorders on the market that can record both DVD-RW disks and DVD+RW ones. These
recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be
finished to be played in commercial DVD players, and to record new data in the
disk after having finished it requires reformatting it, which makes all the data
in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks
(but not of recording them) and vice-versa.
There you are.
