Canon MultiPASS MP730 All-In-One InkJet Printer Logo
Posted on Nov 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon mp730 has stopped printing magenta. We had just changed all the other color tanks (black, cyan, yellow) and magenta stopped printing. We then found we had dislodged the magenta tank (was unclipped). Clipped it back in but still does not print magenta.
  • davidgoff Nov 29, 2009
    Hi, I ran the clean print head a couple of times, then swapped the magenta for the yellow and got magenta printing for yellow. Then swapped back and seemed to get both colours but very poor balance.
    So I carried out the print head alignment process and some settings were way off - after adjusting them good results were obtained.
Anonymous
Level 3:
  • Master 466 Answers
  • Posted on Dec 01, 2009
Anonymous
Master
Level 3:
Answers
466
Questions
0
Helped
182921
Points
1494
Unclip it again and clean contacts on both printer and cartridge with a lint-free paper and a little alcohol (isopropyl alcohol if you have it). Clip it back and run the head cleaning and alignment routine; that should be enough.
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
1helpful
2answers
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
1helpful
Canon MP610 Printer
You cannot switch to the larger black cartridge. You are using a CMYK (Cyan, Yellow, Magenta, Black) format for printing color images.
The larger cartridge is used for text only. The smaller black cartridge is used for color or graphic images.
If the black cartridge was not present, every time you needed black in an image, it would have to come from the composition of Cyan, Magenta and Yellow. This would greatly reduce the life of the color cartridges.
Don
Blue (CYAN) not printing despite changing ink tank
enough ink b ut not printing at all - blank paper on every time despite noise as if printing
Printer prints wrong colors
As a guess you have the color ink cartridges in the wrong places. Take them out and run a whole bunch of head cleaning routines. I'd expect the wrong colors for a while until the incorrect ink has been flushed out.
Check your manual or setup guide for the actual order . Usually black-cyan-magenta-yellow
Yellow Prints in the other colors
Problem seems to be with your Ink Tank(s) or Printing Head. Replace both of them one by one and retry.
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
old marine
old marine
ZJ Limited
ZJ Limited
