Question about Fuji FinePix A605 Digital Camera
SOURCE: Finepix Z5 Troubleshoot
The problem is with either the flash unit, or the flash transformer. Unfortunately the only way to fix this, is to take it to a service center.
Bob
Posted on Feb 26, 2008
SOURCE: Pictures from Kenny Chesney concert
Hello I have the tools required to recover your pictures! Im just not able to get the chat.
Posted on Jul 15, 2008
SOURCE: Fugi Finepix S3800, compartment for
In this case u can contact the Customer service ph# 800-659-3854 and im sure they can fix ur problem
Posted on Aug 04, 2008
SOURCE: flash not popping up or
The S700 does NOT have a manual release for the flash to pop up, but it DOES have a spring already. DO NOT try to force it! Set the flash to "FORCE", leave your lens cap on and waste a shot to allow the flash hood to pop up. Reset your flash to the desired setting and now the flash is already open and ready for use without the delay and the startling effect it has when your concentrating on framing your shot. As for the other problem of no flash in any setting: Check your menus to see if you have the flash totally disabled, check your batteries, does the "charge indicating light" come on at all between shots? In RARE cases, the actual bulb that flashes may be burned out, or a component in the flash circuit itself,such as the capacitor, may have gone bad. Did the flash ever work? If under warranty, return for repair or replacement. There are NO user serviceable parts in these tiny cameras
Posted on Jul 16, 2009
