Good day,
First, measuring the coil Resistance doesn't work. A valve can measure fine, but refuse to open.
First, shut the water off to the house at the meter. remove the line from the valve, put the line into a bucket, and have someone turn the water valve on full for a 15 second or so count. The water must come out and strongly.
Unlike an automatic washer, the ice maker is a time fill. 7 seconds period.
Second, it is not unusual for the file tube that runs from the back of the machine and into the back of the ice maker to ice up.
Common problem, and is caused by the water valve on the back rear of the machine to leak slowly on the off cycle. Water valve must be replaced with new.
Remove the ice maker to inspect that fill tube. If iced, thaw out.
Beware of hair dryers. Too much heat can cause serious problems if plastic and/or vinyl parts get melted.
I don't recommend heat. A pain, but unplug the machine for 12 hours with the freezer door open.
