Hi its me again, i tried your suggestion and thanks though im sad to say it didn't work i may have change the settings to many times so im not sure where it went wrong but in any case i will just show you my settings on my recovery menu and it is as follows: CONFIGURATION > *Skip Sony Logo *Hide corrupt icons *Game folder homebrew the other choices is 5.00> *Autorun program at /PSP/GAME/BOOT/EBOOT.PBP *UMD Mode *Fake Region *Use VshMenu *XMB Usb Device other choices are (flash 0 -3 , UMD Disc) *charge Battery when USB cable plugged *Use M33 network update *Hide PIC0.PNG and PIC1.PNG in game menu *Use version.txt *Speed up MS access other choices are (VSH & GAME , VSH & POPS , GAME , GAME & POPS , POPS , NEVER , ALWAYS) ADVANCED CONFIGURATION: *Plain modules in UMD/ISO *Execute BOOT.BIN in UMD/ISO *XMB plugins *GAME plugins *POPS plugins Oh and im using PSP2000 Slim & Lite version 5.00 M33-6 thanks in advance and thanks to Master WhOlsDlz for answering in previous post.
Try this whether it work or not?
1. Menu
2. Settings
3. Restore all factories
4. Put your security code 12345.If you didn't changed.
In case if you had changed it than put your code that you had changed.
Try the following. Remove all the cartridges. Then switch Printer off.. Wait a minute or 2 then switch printer on again and install the cartridges again. Also make sure that on the cartridges the little golden contacts are clean.
If that didn't work try doing the following. It will reset your printer.
1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5. Release Power button 6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 7: Press Power to set data
Hi Hallie, Have you tried this? Go to Start --> Run, and type in services.msc.
A window will pop up with a list of services. Scroll down to Windows Audio. Right-click and click on Properties. Make sure that "Startup type" is set to automatic. Also, make sure, under "Service status," start is selected Have you checked for the drivers in device manager? Try The above and post back we will look into it. Thank you.Cheers!!
You should go to the nearest sales and service centre and get the device fixed. Since you purchased it yesterday, it is in warranty and instead of trying to fix it on your own you should claim the warranty.
Hi, Plug the USB keyboard into another port (preferably one at the back) restart the PC and enter the BIOS again, this time go through the BIOS and set all the USB controllers to enabled, hit F10 save the changes and exit the bios. The computer will restart and you should now be able to use the USB keyboard to install the OS. Please post back if you need anymore advice.
Not all replacement parts are available online. If you are unable to
find a desired replacement part, please contact Logitech Customer Sales
at 1-800-231-7717, Monday through Friday from 6am - 6pm PST.
problems with memory card of phone is after they get corrupted it might not work again... i suggest trying the card on other phone, if the problem still persist... im sure that the memory card is busted and sad to say but its time to buy a new memory card...
