Computers & Internet Logo
Posted on Nov 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to install hp pavilion dv1000 laptop cooling system
Anonymous
Level 3:
  • Master 2,567 Answers
  • Posted on Nov 28, 2009
Anonymous
Master
Level 3:
Answers
2567
Questions
0
Helped
671495
Points
7153
Here's a direct link to the service manual for this laptop model:
http://h10032.www1.hp.com/ctg/Manual/c00636251.pdf
On page 168 of this PDF file, section "5.18 Heat Sink" explains how to install/uninstall the heat sink.
On page 170, section "5.19 Fan" explains how to install/uninstall the fan.
Hp pavilion dv1000 driver for win7 32bit
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
No audio
Welcome to Fixya. Can you please check if the driver of your sound card is properly installed. You can download the driver using the link below. Select the model of the computer and the operating system then download the audio driver.
HP Pavilion dv1000 Driver Download
Thanks for using Fixya.
2answers
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
19helpful
4answers
Windows 7 hp audio hp pavilion dv1000 drivers I upgraded to windoes 7 from xp and i have no sound went to alot of sites but nothing
Sir, i have HP Pavilion dv 1000 (XP operating system). Recently, i upgrade it by Window 7 but Now audio driver is not working properly now. pl suggest to solve it.----- pratik
3answers
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
I have a hp pavilion dv1000 laptop and it randomly hibernates
Go to the control panel > Power Options, click on the hibernation tab and uncheck it. Click on apply and ok. Hibernation can damage older HP systems such as the DV1000 that is running XP, make sure it is turned off and also go through the power settings and change the setting for closing the lid on the laptop. Change the setting to "Do Nothing". This will keep your system from getting corrupt.
2helpful
HP Pavilion dv1000 blank screen
It may not even be caused by the graphics display driver at all. Your Hard Drive may hae BAD SECTORS and the computer is battling to read the system area of the hard drive... Make alse sure that the hard drive commections are fine
2helpful
I need driver hp pavilion dv1000
Hp has not posted a driver for Vista for the laptop. The XP driver is available at
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=435618
Install the driver and check if it works. Comment if it doesn't
12helpful
7answers
HP Pavilion dv1000 PC Notebook Audio Problem
There are two different audio cards shipped with Pavilion DV1000 series Notebooks.
If your Notebooks belong to DV1600 series, your Notebook should have been shipped with Conexant High Definition Audio card.
This can be one of the reason why you are unable to install the Conexant AC Link audio drivers in your Notebooks.
You need to install Microsoft UAA Drivers first before installing the Conexant High Definition Audio Drivers in the Notebook.
Download the Microsoft Universal Audio Architecture(UAA) Drivers for your Notebook from the HP link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Please save the file in the Notebook and double click it after the download completes to install the drivers. Restart the Computer once the installation of the Microsoft UAA Drivers is completed.
Now download the Conexant High Definition audio drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32864.exe
Save the file and double click on it once it is saved to install the Drivers.
This should solve the issue with audio in your Notebooks.
Hope this helps...
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
