Question about HTC Touch HD Smartphone
My touch screen froze, so I did a soft reset. This didn't work. So I did a hard reset. All seemed to be going to plan until the 'Align screen' appears. I align the screen as instructed but instead of going to the next step, the ' Align screen ' returns again. I have done numerous soft and hard resets, all with the same end result ' Align screen '. My phone is a HTC Touch HD Smartphone. I would appreciate your help on this matter.
Posted by robertemile on
Brandon Nugent
    New Friend:
  • 112 Answers
Whenever you do the alignment touch the spot on the screen with the stylus and hold the stylus on the mark until it moves to the next corner.... this may work
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
Posted on Nov 28, 2009
My htc touch pro 2 smart phone screen is locked and seems to be frozen, I have reset and removed battery with no results how can I unlock this screen?
It might be a hardware problem, if you already tried the soft reset (removing the battery) then the next step is to hard rest. This will lose all your information and settings, the phone will be like the first day you took it home (and hopefully the screen will work)
First make sure the phone is off, then press and hold the TALK/SEND, END and POWER buttons until you see a message on the screen.
Once the message appears release the buttons and press the volume up key for a hard reset.
May 31, 2010 | HTC Touch Pro2 Smartphone
My HTC Touch Diamond Screen is not working. Hellllllllllllppp THe screen seems to out of alignment but i have a security code and i cannot get oast that to re-align my phone.
Hello :
Did you try soft reset or hard reset .? If those both didn't solve the problem , then it must be a hardware failure . For hardware failure , i recommend you to replace it with new one , if you still have the guarantee .
good luck .
rate please !
Mar 18, 2010 | HTC PPC-6800 Smartphone
Screen is frozen at the green Align Screen. Tried
Here is your drivers link kindly go and get it
http://www.filebuzz.com/findsoftware/Driver_Intex_IT_102WC_Webcam/1.html
Sep 07, 2009 | HTC Touch P3450 Smartphone
Touch screen froze
take the back off it and down in the corner youll see a small red button press this with stylus tip and phone will restart
Mar 01, 2009 | HTC Touch Diamond Smartphone
Screen align problem
try to do hard reset if its not works
try to update rom image
if still not works try to replace your touch screen to new one
Dec 15, 2008 | HP iPAQ H3950 Pocket PC
Touch screen & key board with stick does not respond
try aligning the screen...
settings > screen > general > Align Screen
If that doesn't work try hard reset... i.e.
press the two soft keys and the reset button using stylus...
If its still not working do soft reset:
settings > system > Clear storage
but remember to take back up of phone before doing this..as it will erase all your data...
and do tell me if it worked or not...
Jun 25, 2008 | HTC P3300 Smartphone
Touch screen not working
the only solution i have found...replace the phone
Feb 20, 2008 | HTC Touch P3450 Smartphone
Palm z22 touch screen screwed up
clean the touch screen and go under the edges w/ a bankcard to remove any dirt.
then do a hard reset -- worked for my z22
c boekema
Jan 14, 2008 | Palm Z22 Handheld
HTC Touch HD Smartphone Logo
718 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
