Sr.1320nx will not start. makes a beeping noise.
Will not start. makes a beeping noise. will sometimes start after several attempts. will not go to desktop.
Posted by pinedotucson on
  • pinedotucson Nov 29, 2009
    the beep sounds like 1 second on 1 second off
  • Anonymous May 11, 2010
    Can you describe the beeping noise? long consistent beep is usually a memory error but i cant tell you for sure until i know the pattern of the beeps
Anonymous
    Guru:
  • 366 Answers
Could be a memory failure or a hardrive failure remove every thing pluged into back liek keyboards cameras printers mouses and try turn it on, try run a dinostic cd you might have it with your pc and it will tell you what problem is, or it could even be a hard drive failure. you can try removing memory dimms one at time and each time try to start it up.
Posted on Nov 28, 2009
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
2002 suzuki xl7 makes beeping noise under the dash when applying the brakes
Top up the brake fluid and make sure the brake stop lights are all working.
Feb 03, 2018 | 2002 Suzuki XL-7
CD-RW drive won't open, only beeps when trying to open.
Look for a hole on the front tray a little bigger then a pinhole. Straighten out a paper clip and insert it into the hole to eject the CD.
Mar 20, 2013 | Dell Inspiron 8100 Notebook
My Olympus Camedia C-750 will not turn on. When I start it, the screen looks normal but then goes blank. it stays lighted and then beeps several times then makes a noise like a picture has been taken,...
If those batteries are definitely good then the electronics of unit have gone haywire. Contact Olympus to see if there is some sort of hidden code to reset electronics to factory defaults.
Sep 05, 2017 | Olympus Camedia C-750 Ultra Zoom Digital...
My saturn sl2 alarm starts to beep when I try to start the car and won't stop for about a minute. Car won't start. My power locks have been disabled(over a year now). It started acting strangely and...
This sounds somewhat similar to a problem I had with my 1999 Saturn SL2. There was "burning and arching" on the fusebox and it was replaced. The first few times my car would make an extra beep noise when locked or unlocked and I believe the radio/clock had to be reset. The problem got worse although sporadic. Eventually the car wouldn't start - not even making a clicking noise and a big variety of electrical components would not work or didn't sound right.
Jul 08, 2010 | 1998 Saturn SL
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Antenna motor will not pull down the antenna & is killing battery
check integrity of battery terminals as well as the lead that extends to the starter motor. make sure it is done up tight too
Jun 05, 2009 | 1999 Lexus RX 300
External hard drive emits noise and disconnects within 60 seconds
please try changing the hard disk compartment and thanks for your question
May 20, 2009 | Computers & Internet
Problem with inspiron 6400 does not ignite sometimes
Samj04011, Not sure I understand entirely what problem you are experiencing. I?m assuming you are using ?igniting? to refer to starting the laptop but it?s making some odd noises and takes lots of time to start. Can you give us some additional information such as: -describe the noise in greater detail; is it beeping and if so are they long, short and how many. These may be beep codes which are a series of long or short beeps, the number and order point to specific errors. -What is displayed on the monitor? -What LEDs light up whey you try to start? Once you?ve given us some more information we can start to figure out what is going on.
Feb 24, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
83 people viewed this question
Ekse
Marvin
Marvin
