Question about Jura Capresso Capresso Infinity Conical Burr Grinder
Cannot remove upper burr
I have a Capresso Infinity Burr Grinder 560. Took it apart to clean, and reinserted the upper burr with soft collar. Then tried to reinsert the bean container, but it would not go in. Tried to remove the upper burr to see if it was in wrong but it will not budge, (It is NOT upside down!).
Can you give me any clue as to how to remove the upper burr?
Posted by hdk333 on
ray gallant
    Top Expert:
  • Jura Capresso Master
  • 68,344 Answers
NOPE I buy pre-ground coffee
Posted on Sep 30, 2017
3 Related Answers
Anonymous
SOURCE: the upper burr stuck upside down!
Yes, this butter knife trick is the way that Capresso customer service recommends. Just to clarify the tip of the butter knife is the only portion inserted...DO NOT shove the entire blade into the grinder. Just the tip in the furthest to the right side of the "smiley face ****" that is on the top of the grinder without the clear plastic hopper. just imagine a birds eye view. Once you have the tip of the butter knife all the way to the right of the "smiley face ****" then just rotate counter-clockwise until it does not go any further. This should have dislodged the top part of the grinding cone and then simply pick it up with your fingers, flip 180 and put it in the correct way.
Posted on Jul 20, 2010
jaybayca
  • 4 Answers
SOURCE: Hmm, I have Capresso Infinity Burr Grinder #560,
I've posted this in a few other places on this site (there are many ways to ask the same question), but try putting the clear bean container back on and untwisting as if to unlock it -- the problem isn't just that we put the upper burr in upside down, but then we locked it into place with the bean container. More info at http://www.fixya.com/support/t4009992-upper_burr_stuck_upside_down or try Capresso at 800.220.5701.
Posted on Feb 10, 2011
bolagirl
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Posted on Aug 20, 2012
The bean container/hopper on my Capresso 560.01 Infinity Burr Grinder is stuck and can no longer be rotated in either direction or removed from the body. Can anyone help me unseat it?
Grinders that are used daily, especially those in coffee shops will eventually wear out. The fine settings for espresso (or even finer for Turkish grind) will wear out the plates even faster. I've seen burrs needing replacement in 3-6 months for coffee shops. Burrs set on this fine position that do not grind or stop usually means a worn burr or gummed up plate. (especially with oily beans). Either problem requires the removal of the burr set and complete disassembly of the grinder. It sounds like your '1st' problem was corrected by permanently 'affixing' the burrs to a set position and now not able to remove them without causing more damage. I did the same to an old grinder I got from the swap meet. But alas, the plastic collar cracked completely and can't be repaired. well got 1 year's worth of use and it was cheap.
** Suggest checking with your vendor or MFR for service and/or replacement.
Aloha, ukeboy57
Dec 08, 2017 | Coffee Makers & Espresso Machines
Grinder stopped working today. Tried to clean with no result. Anything I can do to trouble shoot? The timer goes, but no grind...
check to see if the grinder is jammed. Most likely, there was something that's gotten caught in it, and jammed the mechanism.
Feb 27, 2016 | Jura Capresso Capresso Infinity Conical...
I took everything apart to give it a good cleaning and now all settings produce a very fine grind. Any thoughts?
I had the same problem with too fine a grind when I took mine completely apart to clean (including the lower burr). The solution I finally came around to was to further tighten the star-shaped screw which holds the lower burr assembly in place. I had originally just tightened it until the lower burr until the lower burr assembly started to turn with the screw, but that wasn't enough. So I held the assembly in place and tightened the screw further and I'm back to my previous grind coarseness/fineness.
Jan 13, 2014 | Jura Capresso 560 Electric Burr Grinder
How to change burrs
1 take the bell(bean container) carefully out. 2 disassemble the upper holder of burr 3 you will see now the burrs, clean good coffee remains than disassemble the burrs 4 after disassembling burrs clean good the lower and upper burr holder. 5 carefully switch on the grinder tan switch off(few seconds) during lower plate is rolling touch with marker the surface of burr holder very softly, if it is ok you will have complete circle / if it is deformed you will have incomplete circle( that you must compensate with letter tape ) after each correction you mark the burr with marker to see did you achieved perfect result. once you have lower burr in place you screw bolts in upper bur holder and assemble it back in his place.
Feb 11, 2011 | La Pavoni Jolly (PA-JL) Electric Burr...
Hmm, I have Capresso Infinity Burr Grinder #560, and I accidentally placed the upper burr back in upside down. Now it is stuck. I do not see the "black section with a long slot" around the blade.
Thanks to jaybayca!
Jan 08, 2011 | Jura Capresso 560 Electric Burr Grinder
I accidentally placed the upper burr in upside down. Now it is wedged in and I can't get it out. Any suggestions?
Spring loaded ball bearings - does the ball bearing sit on top of the spring or below the spring??
The ball bearing is a check valve. The ball should be in the input side of the water with the spring underneath.
input side ----->( O/////)-------> output side
Feb 21, 2010 | Jura Capresso Capresso Infinity Conical...
The upper burr stuck upside down!
Jan 30, 2010 | Jura Capresso Infinity 565 / 560 Grinder
Cleaning La Pavoni Burr Coffee Grinder
You'll need to remove the hopper and grind out all the beans. Then, with the lock tab depressed (if it has one), unscrew the grind adjusting collar out of the body. Once it's out, there are three screws (sometimes only two) holding each burr. Remove screws and separate the burrs. Clean away!
Be very careful putting it back together so that you don't cross-thread the collar into the body. Clean threads can help this.
Jan 02, 2008 | La Pavoni Burr Coffee Grinder - Black
Coffee Makers & Espresso Machines Logo
358 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
