Question about Samsung HL-R4667W Rear Projection Television
Picture is scrambled after power surge. Have a
Problem on Samsung DLP TV (HL-R5067W) Picture is scrambled after power surge. Have a blue & green plaid pattern. Audio works. PIP works. TV guide menu is not scrambled.
Posted by chapelmouse on
  • chapelmouse Nov 28, 2009
    Image is scrambled on DVD as well.
Anonymous
  • 647 Answers
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Posted on Nov 28, 2009
  • Anonymous Nov 28, 2009
    The common fault(that would cause this symptom) is The DMD board - that's the digital board that drives the Optical engine.Since the on screen display and pip arn't effected I would definetly rule out color wheel, lamp or light engine. At this point it would be best to get an estimate from a samsung approved servicer.
    Investigate DMD board further through Google to see what I mean.
    Item Number
    Description
    Price
    Qty
    Buy
    BP96-00678D
    ASSY DMD BOARD P
    $492.57
    © 2009 Global Electronic Supplies Inc.
    All Rights Reserved.
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV HL-R5067W green vertical bars on screen no picture
This is going to be a bad digital board. It is a very common issue with the HLR series.
Aug 30, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Remote Code Samsung 50" DLP HL-R5067W
022 036 043 159 160 170 175 212 215 702 713 706
Dec 14, 2008 | Samsung 50" Slim-Depth DLP HDTV
Samsung HL-R4667W Rear Projection Television Logo
542 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
