Question about Directv RC32RFK Remote Control
Can't get DirectTV rc65 remote to program the tv volume and power, tried all the codes.
Posted by eltiante23 on
Anonymous
    New Friend:
Cant connect RC65 to Samsung 46" LED TV or Panasonic Blue Ray. Have followed instructions and tried all codes. no luck :(
TV model is: UN46B6000
Blue Ray is: BDP-120
TXS
Posted on Dec 19, 2009
Do you have the code for programming the volume on a DIRECTTV remote?
go please to www.fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jul 10, 2012 | Daewoo DTQ-13V5FC 13" TV
Tip
DirectTV RC65 Code Search
TIVO DirectTV RC65 Remote Control Programming by Code Search
Here are the steps to program your TIVO DirectTV RC65 remote control using Code Search:
  1. Turn on the TV or component.
  2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by one of the following four digits: 0 for Sat box, 1 for TV, 2 for VCR/DVD/PVR, 3 for Stereo.
  5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
  6. Point the remote at the TV or component and press CHAN UP. Repeatedly press CHAN UP until the TV or component turns off or performs the action you selected in step 5.
  7. Use the CHAN DOWN key to step back a code.
  8. When the TV or component turns off turns off or performs the action you selected in step 5, stop pressing the CHAN UP key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available.
If you know the 5-digit code you want to use, follow these steps.
To download and electronic copy of the DirectTV RC 65 manual, click here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
Tip
DirectTV RC65 Programming
Here are the steps to program your TIVO Direct TV RC65 Remote Control:
  1. Locate the 5-digit code for your DIRECTV® Receiver. (See Users Manual)
  2. Power on the DIRECTV Receiver.
  3. Slide the MODE switch to the DIRECTV position.
  4. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
  5. Using the number keys, enter the 5-digit code. If performed correctly, the green light under the DIRECTV position flashes twice.
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Your TIVO DirectTV RC65 remote control is now setup to control your DVR. A digital copy of your remote's owners manual is available here.
Instructions for the RC65 Code Search function to find compatible remote codes are here.
I hope that helps.
Looking for the direct tv RC65R remote control code for the RCA LX40FHD41YX9 HDTV
RCA TV codes for the DirectTV RC65 are:
11547, 11447, 10047, 10051, 10093, 12187, 12002, 11958, 11953, 11948, 11922, 11919, 11917, 11781, 11347, 11247, 11147, 11047, 10774, 10747,
10679, 10278, 10174, 10135, 10090, 10038, 10029, & 10018.
Instructions for entering the codes are here.
Instructions for searching for the proper code instead of trolling through that list are here.
If you'd like a digital manual for your RC65, click here.
I hope that helps.
Mar 31, 2010 | RCA L40FHD41 40. in HDTV
I need remote code to control my GPX DVD model D108S with my Directv controller model RC65.
GPX DVD codes for the DirectTV controller RC65 are 20699 or 20769.
Instructions for searching for the proper code if those two don't work, or for other devices, are here.
I hope that helps.
Mar 06, 2010 | GPX D108S DVD Player
Tip
DirectTV RC65 Remote Manual
Tivo DirectTV RC65 Remote Control Manual
Have you lost your TIVO Direct TV RC65 Remote Control Manual?
Would you like a digital, searchable, pdf version for reference on your computer?
The TIVO Direct TV RC65 Remote Control Manual is available for download here.
In it, you will explanations of is buttons and features, and directions for setting the remote up for use as a Universal Remote, controlling all your other AV components.
Directions for entering DVR programming codes are here.
Instructions for using the RC65 Code Search function to find remote codes are here.
I hope that helps.
Can't program rc65 directv remote to control hr21-700 receiver
I believe the codes 00001 and 00002 are valid for all DirectTV receivers.
I hope that helps.
Jan 25, 2010 | Directv HR21-700 DTV Receiver
Program remote
Hi there, I will need the Full model number of your TV, then i can see whay i can do.
Jun 13, 2008 | Emerson EWL20D6 Television
Remote problem Hisense
I GOT A NEW HD WIDESCREEM POLAROID. DIRECTTV CONTROL PUTS ON POWER ON TV,CHANGES CHANNELS BUT DOES NOT CONTROL VOLUME NOR CONTROL DVD ANDVCR PLEASE HELP GODWIN
Jan 08, 2008 | One For All URC-4021 Remote Control
Directv RC32RFK Remote Control Logo
2,965 people viewed this question
Top Directv Televison & Video Experts
Lee Hodgson
Lee Hodgson
ray gallant
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
