Question about Jet 3 Ultra Power Chair
HOW DO I REMOVE THE SEAT FROM A JET 3 POWER CHAIR
Posted by peggykimble on
oregoon
  • 175 Answers
It has a lock lever on the side. Push the lever and turn the seat slightly while lifting up with both hands. Sometimes, they need a pretty hard **** to get it to release, but it will come right off.
Posted on Jan 08, 2010
Replace battery for the jet 3 ultra
\hmm what do u need to know? how to replace battery?if so take seat off then take off shroud and u will see batterys,make a wiring diagram of how batterys are conected before u remove them, good luck
Jan 20, 2014 | Jet 3 Ultra Power Chair
I want to take the batteries out of the power chair, how can i do this
Flo First you have to unplug the nine pin connector at the rear of the chair and the 3 pin charger plug. Then there is a handle under the right side of the seat. Push it forward to release the pressure on the seat post. Now the hard part have someone with some strength twist and pull up on the seat at the same time until it comes off the seat post. After the seat is off then remove the plastic shroud covering the base and there you will find the batteries. Unplug the battery cables from the wiring harness and lift out them of the base. Hope this helps you
Mar 02, 2011 | Jet 3 Ultra Power Chair
I require a backrest with a headrest for a jet 3 ultra power chair
well ,This head rest you are wanting only comes on the captains seat model , Look for a captain seat back,make when you do find one that it came off a jazzy /jet 3 and that the seat with is the same as yours they should be universal a easy swapout of the back.
Good luck,hope i was helpful.
Jan 19, 2011 | Jet 3 Ultra Power Chair
How do i remove the chair. I want to change the batteries
Bob First unplug both connectors from the rear of the chair. Then on the right hand side under the seat push the small handle forward until it stops, then rotate the seat and pull up at the same time the seat should lift off the seat post. Carefully place the seat on the floor next to the base. Remove the shroud pulling upward to release the velcor fastners and voila!! the batteries. Now if the seat is hard to pull up try twisting it back and forth to help get it loose from the seat post. You might need some help in lifting because this seat and attached parts are heavy. After replacing the batteries grease the post to help getting it off easier next time. Hope this helps you
Sep 29, 2010 | Pride Mobility Products New Pride Mobility...
How to remove the seat
Bubba, Under the front of the seat is a latch that you must release there is a rubber block that must be rotated forward to be able to release the two little knobs that it is wedged between Rotate the knobs inward and lift the front of the seat. the seat will flip toward the rear of the chair and you now have access to the batteries. to remove the seat disconnect the joystick cable from the base and slide the seat forward after you have it tilte back and lift it off the base. Hope this helps you
Aug 26, 2010 | Jet 3 Ultra Power Chair
Directions to replace the battery in a jet3 power
Unplug the joystick cable under the seat remove the seat if on a post lift handle on right side under seat and lift seat off post if not look for release levers behind front seat post and seat will rotate backwards to give you access to the batteriesdisconnect battery cables and install as on old batteries to new ones and reinstall Hope this helps
Aug 02, 2010 | Jet 3 Ultra Power Chair
My speed indicator lights are constintly flashing- the chair works fine though
You don't say what sort of chair you have, but if it has tilt or power seating system, the speed lights flashing could be a power-limiting warning, which means you have the seat tilted or raised too high for full power so it is limited to going slow. Lower seat and then try to drive it an normal speed. If the seat isn't tilted or raised and lights are flashing, then the switch on the chair that senses the height or the tile is probably faulty and would require replacement. Do NOT disable or bypass the switch as it is a safety device to prevent unsafe operation.
May 23, 2010 | Jet 3 Ultra Power Chair
How do i remove the battery?
Remove the seat and then the support that covers the batteries
Oct 20, 2009 | Pride Mobility Products New Pride Mobility...
How do I remove the chair from my Pride Mobility Jet 3 power wheel chair? The manual just have one line of description! Do I need to remove the chair before getting by hands on the battery? My Jet 3 is of...
There's a lever on the side of the chair that you disengage to unlock it. First, make sure the chair is in gear and power is off, then unplug the Joystick from the base; just follow the cable coming out of the joystick to the rear of the chair where it plugs in and rock it back and forth to unplug.
Unlock the seat with the lever, and turn the seat slightly to the left or right and lift up. Usually, it will come right off. If it's been a while since it's been removed, or if a heavier person has been bouncing atop it, it may need more coaxing. Try squirting some WD-40 at the base of the seat where the pole connects and let it run down into the shaft of the pole. Wiggle seat back and forth a bit and try lifting at the same time.
Now you can access the batteries by lifting up on the corners of the cover called the shroud. These are held on by Velcro strips so just pull up and they will give way. You will see the two batteries inside. Replace them with sealed, gel-acid deep-cycle batteried, about 32-34 amp-hour rating. Fully charge for two or three hours before using. On first uses, let the batteries discharge almost to the red zone before charging overnight. After a week, they will be well broken in. Good luck.
Jun 30, 2009 | Jet 3 Ultra Power Chair
JET 3 POWER CHAIR SEAT REMOVAL
Sometimes it just takes some real elbow grease to remove those. Try two people one on each side.
Mar 30, 2009 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
1,279 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
