door lock error...door lock mechanism broken,,,replace door switch,,,if your lock out remove toe panel and reach up and pull tab,,always unplug first...good luck
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
remove bottom panel reach up from bottom to lock area pull the small tear shaped release to open door if water still in tub pump may be plugged to clean turn handle on pump to left and pull out trap and clean ..after dipping as much water out as possible
Well there is one of two control boards that is malfunctioning, most common is the Machine (or Main) control board, there is also a display pc board in the control panel, but i have had few problems with that control. Unfortunately the main board is $300.
