1. Power off machine. 2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle. 3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal. 4. Reassemble KCup cradle and reinsert it back into coffee maker. 5. Power on machine. 6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage 7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on. 8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours. 9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless. 10. Set Auto-OFF, if preferred.
I used an air compressor with low pressure. Put nozzle on the tip of each needle and gave a short burst. Before it would not heat up. Now works fine. No disassembly required.
SOURCE: Never gets ready, keeps shutting off.
Try using a straw. Use it to blow thru the hole where the reservoir attaches. I tried this on my B40 and worked.
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
SOURCE: platinum B70 keurig coffee maker water heats up
SOURCE: Need a new check valve for a Keurig B70 coffee maker
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://igotsweetdeals.ecrater.com/
We have most parts for Keurig b30, b40, b50, b60, b66, b70, and b77.
If your parts not listed just send us an email and let us know what part you need. In most cases we can have the part pulled and shipped the same day!
Our parts are used and the prices are exceptionally fair. Ask about our scratch and dent parts to save more money!
If you have any questions about your Keurig or your having a problem just give us a call and we may be able to help you.
SOURCE: MY KEURIG B70 IS CONTINUALLY PROMPTING TO "PRIME"
Hi, Lauren..
You can download another manual here.
Cleaning any coffee brewer is essentially the same. The easiest way is to brew one or more pots of white vinegar... it'll stink up your kitchen, but it's effective at removing build-ups and mineral deposits. Be sure to follow up these "vinegar brews" with several "plain water brews" to remove all the vinegar!
Also, if your water reservoir isn't clean (open the lid & do a finger swipe), you can use a brush to clean it or - what I do - wad up a paper towel or two, attach it to the end of a long-handled wooden spoon, and use that to get down deep into the reservoir & scrub it as much as you can before the vinegar treatment.
Alternatively, you can spend $3 or $4 for packaged cleaning compounds at stores like Williams & Sonoma.
