Turn your printer off. Turn it back on again, go to menu -> Machine Info -> Reset Menu, choose Belt Unit, OK, then reset the counter pressing 1, then press stop/exit. Same for drum.
If however this won't work, go to the following page and look at the instructions. Do what it says, but just pull out the drum unit and put it back in, the same with belt unit, just pull it out and put back in.
Then do the reset procedure as described. Should fool the printer ;)
Forgot the link, put it in the second post. Here it is:
http://welcome.solutions.brother.com/BSC...
SOURCE: Brother DCP-9045 CDN end of drum life override,
If however
Link: Brother instructions
Thnaks! I had found this previously:
When you replace the belt unit with a new one, you need to reset the belt unit counter by completing the following steps:
Turn on the machine's power switch.
Press Menu => Machine Info. => Reset Menu.
Press the Up or Down Arrow key to choose Belt Unit.
Press OK.
Press 1 to reset the belt unit counter.
Press Stop/Exit.
However, "Reset Menu" is NOT an option in my menu, that is why I posted it here.
Any other suggestions?
