Question about Dremel Variable - Speed Multipro Rotary Tool 395
Motor works but no drive to shaft.
My dremel 396 runs fine(motor) but the shaft(ie the part the chuck hangs off) is not spinning so it's not useable.I can hang on to the shaft with the motor running flat out, there is no drive to the shaft.The shaft lock still works.Any thoughts would be much appreciated.Thank you.
Posted by geoffwatson on
Anonymous
    New Friend:
My 15 year old Dremel 395 had the same problem so I took it apart. There is a plastic spline between the motor and the output shaft to the chuck . My plastic spline was split and had many of its teeth sheared off. The shaft lock acts on the output shaft side of this spline, so it was ok. Otherwise everything looked great; bearings ran free & had little play free, brushes ok. To be fair, my Dremel had seen hard use & doesn't owe me anything. No luck so far finding replacement spline parts, which if available should be easy to install. To take apart your tool, just google "Dremel Disassembly". GOOD LUCK!
Posted on Mar 31, 2010
  • Anonymous Mar 31, 2010
    I'm George_jr7. Here is the email, I just got from Dremel-looks like a simple cheap fix:
    Hello George,
    Thank you for your e-mail. The tool you have is our
    old 395. Our new tool is the 300 series.
    The tool that you require parts for was discontinued many years
    ago. Limited parts are available from Dremel.
    Inside the tool is a flex coupling and spline driver.
    The flex coupling is # 2615294309 and the price is $ 1.25.
    This is the hollow plastic sleeve about 1" long with grooves on
    the inside, that goes between the motor shaft and the output shaft.
    The spline driver is # 2615294308 for $
    1.00.
    Spline driver sits on the direct end of the motor shaft. The flex
    coupling sits over the spline driver. Spline driver is about 1/4", hard plastic
    with grooves on the outside.
    Total shipping for orders under $ 5.00 is $ 2.50. Orders over $
    5.00 is $ 4.00. There could be a tax charge
    depending
    on which state you live
    in.
    Here is how to
    order:
    Call Dremel Customer Service at 1-800-437-3635 , Monday-Friday
    from 7 am to 6 pm central time. VISA, MasterCard or Discover to place a Visa,
    MasterCard or Discover order.
    To order by mail:
    Dremel
    4915 21st
    Street
    Racine WI
    53406
    If you have further questions please let us
    know.
    Regards,
    Shirley K. Ludvigsen
    Dremel/Rotozip Customer Service
    4915 21st
    Street
    Racine, WI
    53406 USA
    1-800-437-3635 ext. 3636
Why does my drill chuck seem to disconnect from the motor?
from pos 32 gear and the drive shaft on the armature can be worm out. or something was broken else.
Detail
Jul 23, 2014 | Dewalt DW505K 1/2" Hammer Drill
How do cars with clutches work?
Clutches are useful in devices that have two rotating shafts. In these devices, one of the shafts is typically driven by a motor or pulley, and the other shaft drives another device. In a drill, for instance, one shaft is driven by a motor and the other drives a drill chuck. The clutch connects the two shafts so that they can either be locked together and spin at the same speed, or be decoupled and spin at different speeds.Clutches are useful in devices that have two rotating shafts. In these devices, one of the shafts is typically driven by a motor or pulley, and the other shaft drives another device. In a drill, for instance, one shaft is driven by a motor and the other drives a drill chuck. The clutch connects the two shafts so that they can either be locked together and spin at the same speed, or be decoupled and spin at different speeds.
-------------greebid.com
Nov 07, 2013 | Cars & Trucks
Have Dremel MOD 395 motor runs and speed control works bot shaft won't turn--worth fixing ??? and how
Hi Larry, The tool that you require parts for was discontinued many years ago. Limited parts are available from Dremel. Inside the tool is a flex coupling and spline driver. The flex coupling is # 2615294309 and the price is about $ 1.25. This is the hollow plastic sleeve about 1" long with grooves on the inside, that goes between the motor shaft and the output shaft. The spline driver is # 2615294308 for about $ 1.00. Spline driver sits on the direct end of the motor shaft. The flex coupling sits over the spline driver. Spline driver is about 1/4", hard plastic with grooves on the outside. Total shipping for orders under $ 5.00 is $ 2.50. Orders over $5.00 is $ 4.00. There could be a tax charge depending on which state you live in. Here is how to order: Call Dremel Customer Service at 1-800-437-3635 , Monday-Friday from 7 am to 6 pm central time. VISA, MasterCard or Discover to place a Visa, MasterCard or Discover order. To order by mail: Dremel 4915 21st Street Racine, WI 53406 USA 1-800-437-3635 ext. 3636
Feb 14, 2013 | Dremel Variable - Speed Multipro Rotary...
Generator is running perfectly but wont put out any power?
Hello, you will need to Flash the Field. With the generator running, plug a drill motor into one of the 110 volt recepticles. Now for the DANGEROUS part. Pull the trigger on the drill.........now with the other hand..........Quickly spin the chuck. DONT hang on to the chuck. The drill should start to run. ..Your done. If it doesnt work, spin the chuck the other way. This polerizes the stator and will work.
BE CARFULL.
Happy Generating!
Let me know how it goes, Thanks
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Jul 28, 2011 | Garden
Dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Jul 19, 2010 | Dremel 395 Variable Speed Multipro Rotary...
My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
The spline driver is # 2615294308 at $ 1.00.
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
Dec 06, 2009 | Dremel Variable - Speed Multipro Rotary...
Motor runs, collet doesn't turn
get a hot glue gun and go to your local hardware store and buy a piece of tubing to fit the collet shaft fill with hot glue and press it on the shaft.
Jun 19, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel repair: The motor spins but the tool does not turn.
I use heat shrink and found one that was larger and cut it down to less than an inch. I heated it with a lighter enough to fit the same size over it. and then heated that one enough to slip inside. I did one more so I ended up with 3 of the same heat shrink tubing (pink) and covered over both of the shafts and heated the whole thing so they all sealed and made a connecting shaft. In a pinch it worked well and never had a problem. there is a picture attached.
Jul 30, 2008 | Computers & Internet
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
1,260 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
Sheldon Dedek
Van Allen
Van Allen
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
