Samsung SCH-a650 Logo
Question about Samsung SCH-a650
Can not move music to my phone. Computer doesn't
Can not move music to my phone. Computer doesn't recognixe the device and I don't have a CD with drivers
Posted by mikenfran on
Anonymous
    Sergeant:
    Champion:
  • 202 Answers
But the driver is not compaitable with ur computer
Posted on Nov 28, 2009
How do i recieve songs through bluetooth from another phone?
Instructions
    • 1
      Verify that Bluetooth is turned on or enabled in both your devices. Most cell phones will have a Bluetooth menu in their Settings or Tools. For computers, you may see a Bluetooth icon in your system tray. If unsure, check your product manual for specific instructions.
    • 2
      Follow the instructions to pair (connect) your two devices. If you are asked for a passkey, try entering 0000 which is usually the default for any device.
    • 3
      When prompted on the other device, give permission for the original device to access it.
    If transferring from phone to phone
    • 4
      Navigate to the song you want to send and hit the button that takes you to the options menu. Choose the option to send your song; depending on the brand of phone it may say "Send" or "Move."
    • 5
      The next menu should ask if you want to use a text message or Bluetooth to move or send the file. Choose Bluetooth.
    • 6
      When prompted on the phone receiving the file, accept it.
    If transferring from computer to phone
    • 7
      Look for an option to browse the contents of the phone. Navigate to the Music or Multimedia folder on your phone.
    • 8
      Navigate to the place on your computer where your music file is kept in a separate window.
    • 9
      Drag the file from its original location to the correct folder on your phone.
    • 10
      Accept the file when prompted by your phone.
Tips & Warnings
  • Pairing is usually the most difficult part of the process. Make sure you read your manual on both devices if it isn't working for you. If you don't see the menu to move or send your music, your phone manufacturer may not allow it. Check your manual or with your carrier's tech support website. This process usually applies to MP3s and not ringtones.
Read more: How to Send Music to a Phone Via Bluetooth ' eHow.com http://www.ehow.com/how_4897391_send-music-phone-via-bluetooth.html#ixzz1xBSYWixA
1helpful
EPSON STYLUS nx410 PRINTER NOT RECOGNIXED BY MICROSOFT LOGO
Look for CD that came with printer to install drivers on your computer. If that is not available, you can search the internet for printer drivers for your specific printer. Make sure your computer has all it's current Microsoft updates too (many times newer printer drivers don't get added to the updates right away).
1helpful
What app touse to transfer music from computer to phone
you don't need a application all you need to do is connect your phone to your computer with the charging cable and then open up the device that appears in finder or my computer. simply drag the music you want on your phone into the music folder. good luck! this works with my phone i hope it works with yours
I do not know how to use the USB cable with my computer to move photos and videos to my PC, is there software or something similar that I need?
i am not firmiliar with this phone but u can try going into the folder "My Computer" and check under devices with removable storage. if you locate your phone click it and it should open up a folder with more folders and so on. they will say things like music, photos, videos, sounds, ect. if your device doesn't show up in "my computer" you should consider buying a mico SD card. you can move your files from your phone to the computer or the other way around.
1helpful
I would like to copy music from Mac computer to Nokia 3710. ``the Mac doesn't recognize the Phone and the Nokia application is not compatible for this model. I don't want to synchronize anything...
Hi, please follow these steps to copy Songs from Mac Computer to Nokia 3710 Cellphone.
Please open Menu>Settings>Connectivity>USB data cable>Then select Mass Storage.
You can also use Memory Card reader to copy songs to Memory Card and use it in the Cellphone.
May 05, 2011 • Cell Phones
2answers
How to move or download a music file to be a ringtone
This option allows you to transfer music files from your PC. In order to use this option, you must install V CAST Music with Rhapsody on your PC. 1. Open V CAST Music with Rhapsody software. Don’t have V CAST MUSIC with Rhapsody software? Download it for free at www.verizonwireless.com/music. 2. Install the device USB drivers before connecting your phone to a PC. USB Cable and Device Drivers can be purchased separately via the Music Essentials Kit compatible with this device. 3. From the main screen on your phone, the SYNC MUSIC V CAST MOBILE PHONE display appears. Your phone should display the message: Connected. Connection may take a few seconds. 4. Drag and drop the song(s) you want to sync from My Library, to your V CAST Music with Rhapsody mobile phone, listed under the Sources tab. Once synchronization is complete, press the END/Power Key and disconnect the USB cable (purchased separately). 5. Under the Music & Tones menu, open My Music to view and play your music. • A compatible USB cable (sold separately) is required for syncing. • Music can also be purchased via V CAST Music with Rhapsody through your PC.
Hope this helps, let me know if I can help you with anything else.
JimmyC
2answers
Plugged the samsung behold into the computer to put music on it and it wont register on the computer
Once again there is a CD that came with your phone that contains all the necessary software to do upgrades personalize and add music videos and pictures to your phone
Samsung digimax 350se- i am having problems getting pictures off of camera
i do not have the software from the camera (cd) and my computer is no recognixing the camera, is there a website i can go to download this software so i can get my pics from the camera to my computer
17helpful
2answers
LG Viewty KU990 pc sync
Do you mean you want to tranfer files or music files from your computer to your phone so you can enjoy music on your device? If so let me tell you that BLUETHOOTH or the SOFTWARE CD are not the best or fastest ways to sync or transfer files from your computer to your phone or vise versa, so Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo.... 2.Select setting
  • Press Mass storage
  • Press OK. 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
  • 0helpful
    2answers
    Razr v3
    first you have to install motorola tolls cd you can find with the package of your motorola acsseries like charger headphone etc when you find the cd you put to your pc and install the software it helps to connect your pc and handset ,
    Top Samsung Cell Phones Experts
    Robert
    Steve
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
