The above answer is not totally correct. Any solution regarding removal of battery, shorting pins together, etc does not work. However, what does work is to use the Dell Asset/Service Tag BIOS Reset Tool. Find an Bootable CD ISO of the tool (can be found on torrent sites or email me and I can send), boot the CD image and when you are asked if you want to delete/change the service tag select "Y". When asked for the new service tag number re-enter your current service tag. Then the tools erases the BIOS and inputs the new service tag. A by-product of this process is that the BIOS master password is removed from the BIOS.I knowthis works because I just did it less than one week ago.
[email protected] my i.d plzz send me boot able c.d
Could you please send me the bootable CD ISO to the email: [email protected]... thanks in advance
please can you also send me the bootable CD ISO to the email: [email protected] , very much thanks in advance
Id appreciate a copy aswell: [email protected],
thanks in advance
Hi, please could you post me the CD ISO (or torrent link or anything useful) to [email protected]?
hi i bought my dell from a tender centre and has bios password on it could you please send me the torrent download would be greatly appreaciated if you could my email is [email protected] thank you would be greatfully appreaciated
Please email me the CD at [email protected]
Very much appreciated. Thank you.
My name is jason can u send me a bootable CD ISO, so i can get past the bios. I have a latitude E-6400, my e-mail is [email protected]. Thank you so much
please my frnd, i luv ur idea... it looks so perfect to me... bt i ll like u to send the Bootable CD ISO on my email... [email protected]
Hey I would appreciate if you could send me the torrent file or sites (whichever is easier since technology hates me) at [email protected]. Thank you!!
Thank you very much for that tip...please send me the CD ISO file on my [email protected] You
Wow I need this CD ISO bad! email it to me at [email protected] MUCH THANKS!
If possible i would like a copy, plzz send me at [email protected]
Thanks mate could you kindly forward a copy to me at [email protected]
can you please send me a copy [email protected]
That cannot be acomplished unless you know the code. If you have electronics or computers knowledge, remove back cover, remove BIOS battery, wait a few minutes, put it on place, place back cover on, and power up notebook. There is no password.
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
I had this problem on an E6400 I purchased from eBay. Ugly. I could boot the machine into Windows 7 without any issues. However, the BIOS was locked. I contacted the folks and Mastermind IT and paid them $20.00 via PayPal. Within minutes they sent me a "master" password that unlocked the machine. It worked and I can change the BIOS now.
Note that I submitted the form at 11:00 PM on a Friday night. The service might be a bot though.
