Question about New Bright 384 Holiday Express Animated Electric Train Set
No power to track and/or train. Power to Holiday Express Train
No power to track and/or train. Power to controller but not to track or train.
Thanks
David
Anonymous
    New Friend:
Power enters through the tender. You must have the tender and the engine both on tracks and linked with electric cable.
Posted on Dec 31, 2009
Bonnie Quintos
    Sergeant:
  • 293 Answers
Check the power circuit that goes to the track if there is an open circuit, open circuit means, break or cut line that can not flow the current going to the track to give a power to the train, ok.
Posted on Nov 27, 2009
Testimonial: "Thanks for your help. David"
Jerry Hunter
    New Friend:
  • 3 Answers
The track clip did break at the power source (repaired). However the train would run and stop . By checking with a voltage meter I found voltage to be spuratic. If you examine the second car it has spring loaded contacts (brushes) that actually ride on the track. This will leave a residue on the track . Clean the track with some fine steel wool and your back in business.
Happy Holidays
Posted on Nov 30, 2014
Robin
    New Friend:
Wheels will not turn when train is on track
Posted on Dec 15, 2013
William Davis
    New Friend:
I have had my track track clip break at the track connector. Had to repair it by wrapping it with some small wire to make contact with the track again.
Posted on Dec 26, 2009
Have power to the track loco cab light turns on red bow lights up but train dosent move at all. No bell or ho ho and nothong on any of the other cars
Try new batteries in the controller Be sure they are in correct. The LED light should come on when it has power. Try moving closer to the train. Usually when the red light is flickering is when there is an engine problem. But here is the Manual just in case you did not have one. Also it has a number for lionel Service in there. Good luck. =) http://www.lionel.com/media/servicedocuments/60287110222501.pdf
Sep 30, 2014 | Lionel Trains Holiday Express G Gauge...
New bright greatland holiday express train
Check the connection from the transformer to the track, and that all the track is well connected. Make sure nothing is touching both tracks, shorting them out.
Nov 25, 2013 | New Bright 384 Holiday Express Animated...
Hi having trouble with our new bright musical holiday station electric animated train set...very frustrating as one of the train tracks broke off a little part so no matter what my husband tries to do the...
Yes, additional track is available from several places, such as Hobbylinc.com, and TowerHobbies.com. At this time, just after Christmas, they are out of stock, however. Walthers.com has them in stock (1-4-2011). You can find extra track on sale on eBay, as well. Be sure to get the track with the brass covers, as New Bright sells battery powered trains that use bare plastic track, which will not work with the 384. A Google search will turn up more sources.
Dec 12, 2010 | New Bright 384 Holiday Express Animated...
We are having difficulty turning on our New Bright Holiday Express Animated Train set. Husband and I have been trying to figure this out for our eager 2 little boys. The remote seems to turn (red light)...
Here are a couple of resources from New Bright:
http://www.newbright.com/public/electric-train-faq
http://www.newbright.com/images/Manuals/384%20ws%20manual.pdf
There is no On/Off switch on the train. Power goes from wall plug to transformer, then from transformer to track clip, which must be attached to the track. A control line goes from the track clip to the controller. Mine has a green light just above the red On/Off button that will come on even if the engine and tender are not on the track. The tender does all the work, and must be connected to the engine and on the track. There are four sliding contacts between the tender wheels that provide contact with the track.
Dec 09, 2010 | New Bright Small Holiday Express Train
I bought the set last year of holiday lionel trains g replaced batteries, have light on remote and noise from engine but no movement? any ideas
If all cars are not properly on the track, the engine does not have enough power to pull the cars. Try with engine and coal car only to zero in on cause.
Dec 23, 2009 | Lionel Trains Holiday Express G Gauge...
WE are trying to get our lionel holiday train going. Is there an on/off switch on the train? the part that goes on the track is lit up but when we puch the remote control with train on the track nothing...
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Will not run or make sounds, control panel lights are on but no response when we push buttons.
Check some of the other solutins I have posted regarding this issue, but you can check to make sure your track is getting power by using a volt meter set to DC. You should measure 10.5VDC between the tracks.
When you set the Treetop tender on the tracks and turn on the power, the tender car should light up if you have power. When you add the loco and plug in the large black cord from the Tender to the Loco, the train should light up as well. If you are getting power you should then be able to press the forward button and the train should start.
Make sure the clips on the track control box are making contact with the rails on both sides. If your getting power to the track and the tender lights up, you should be good to roll.
Dec 12, 2009 | New Bright 384 Holiday Express Animated...
I have power to the track and the controller, but not the train.
I assume you have the Treetop Tender car on the track? The treetop tender is car that makes the electrical connection between the track and the train.
1. Use a volt meter across the track. You should have about 10.5VDC on the track (anywhere on the track)
2. Even without the Loco on the track, the Treetop Tender should light up if you have power to the track. If you have power and the tender does not light. Check the brushes located between the wheels on the tender. These are the motor brushes that pick up the current from the track for the train set. Make sure they are contacting the track.
3. Add the loco to the track and plug in the large black plug from the tender to the loco. Turn on the power and press forward. The train should start rolling.
Try all the functions, bells, ho ho ho, all aboard etc ..
Add one car at a time and make sure that each one lights up before moving on to the next.
Dec 05, 2009 | New Bright 384 Holiday Express Animated...
The train is not responding to the remote.
I had a similar problem with my 11000 Holiday Tradition Express. I cleaned the track with an eraser (pencil-type) and then used a soft cloth to clean any possible residue. After doing this twice, my train is now running.
Dec 04, 2009 | Lionel 11000 Holiday Tradition Express...
Hello: Train won't move
CHECK FOR SWITCH ON BOTTOM OF TRAIN
Dec 07, 2008 | New Bright Toys
New Bright 384 Holiday Express Animated Electric Train Set Logo
2,973 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
gerry bissi
Marvin
Marvin
Are you a New Bright Toy Expert? Answer questions, earn points and help others
